Question about Tomtom GPS
I was downloading an update to my TomTom 700 and had almost finished when the installation locked up. My device then switched off and I cannot switch it on again.
Before I contacted you I just pressed the reset button to no avail.
I then pressed the Reset Button and held it for about 20 seconds and that did the trick
Posted on Apr 30, 2008
My tomtom 700 turns on but just stays on the green screan
Hello
Here is some more information for you to follow to guide you step my step. Device displays a white or red cross
If your navigation device displays a cross after you switch it on, it means that the TomTom application is not installed correctly.
Note: It is normal for the navigation device to show a cross while it is connected to the computer.
The solution depends on which TomTom software is used for updating. Check which software your navigation device uses for getting updates.
Devices using MyTomTom for updates
For navigation devices that use MyTomTom, reset your device.
Devices using TomTom HOME for updates
For navigation devices that use TomTom HOME, you can solve this problem by installing the latest application on your navigation device.Here is also a link that will help you more. This will answer all your questions Mike
http://www.tomtom.com/support/index.php?Language=1&query=red+cross&FID=1898
Oct 05, 2011 | Tomtom GO 700 GPS Receiver
Downloaded updates and now it only goes to "no maps found" screen and does not respond to taps.
Newer maps are not readable by older device software. Please upgrade your TomTom application to the latest version.
  1. Make sure that you have the latest version of TomTom HOME installed.
    • If TomTom HOME is already installed click on Help > Check for TomTom HOME Update.
    • If you do not have TomTom HOME installed, you can download the program fromwww.tomtom.com/home.
  2. Connect your device to your computer.
  3. Open TomTom HOME.
  4. If updates are not offered automatically, click on Update my device.
  5. Download all available updates, restart your device and then reconnect your device to the computer.
  6. When the updates have finished installing use Device > Disconnect Device.
  7. Repeat steps 4 through 6 until the update window shows 'No Items Available'.
Now that you are up to date with your application, check to see if the device still displays the NoMaps Found error under normal operation.
http://us.support.tomtom.com/cgi-bin/tomtom_us.cfg/php/enduser/std_alp.php?p_sid=o6qkN3Wj&p_lva=&p_li=&p_accessibility=&p_redirect=&cat_lvl1=&cat_lvl2=&prod_lvl1=&prod_lvl2=&p_pv=&p_prods=p_srch=&p_sort_by=&p_gridsort=&p_row_cnt=170,170&p_prods=&p_cats=&p_pv=&p_cv=&p_search_type=&p_search_text=no+maps+found&p_nav=foot&p_page_foot=5
Mar 05, 2010 | Tomtom XL 330 Car GPS Receiver
I have a tomtom go 700 when i try to conect it to my pc it comes up as a removeable disc yet when i open it theres no file shown,ive tried going through the device manager but nothing. my pc tell me the...
if your just trying to update the maps and firmware, use TomTom home...you can download it HERE just select your operating system.
after you install tomtom home you will see the option to update your maps and firmware. plug in your go 700 and wait for it to connect to tomtom home, then select your option.
Feb 11, 2010 | GPS
My tomtom go 700 is about 5 years old and i need to update the maps how do i start?
1.First of all check that TOMTOM actually still support this product and only perform updates using a wired network connection - WIFI can drop out and corrupt the downloads
2.Then see if they actually are supplying a new map for the 700
3.Without activating TOMTOM Home, plug your GO700 into your PC and let it recognise the 'drive assignment'
4.Take a FULL backup of all files on the TOMTOM 2Gb disk on your PC NOTE: this is totally separate and additional to any backups you might make with TOMTOM Home.
5.Disconnect your TOMTOM
6.Start your TOMTOM Home software and perform an update check from the 'help' drop down menu
7.Once you have this updated connect your TOMTOM
8.Perform a full backup again with the TOMTOM Home software
9.Search using TOMTOM Home for any GO700 application software updates and install these (NOTE - ONLY INSTALL THE APPLICATION UPDATES)
10.Reboot your GO700 to make sure that it works with any application updates
11.Re-connect your TOMTOM and this time perform a search for map updates to purchase and follow the instructions.
12.It is very likely that TOMTOM Home will say that there is not enough space on the drive to install the new map, it will follow an automatic process to remove your old map and then install the new one that you have purchased on lne from TOMTOM.
13. If Home has installed your new map correctly, when you log off and disconnect your GO700 it should then initialise - the long time bar rebuidling the maps and then start up normally. It can be necessary to reset your GO700 using the rest button under the base.
GOOD LUCK, This is currently a very messy process but one which seems to work for recovering the GO700 in the event of a failure, TOMTOM have been hopeless for me in getting any maps installed on a GO700, so this is my way of getting round their lousy support service.
Jul 18, 2009 | Tomtom GO 700 GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Upload latest western europe map v7.20 to TOMTOM 700 not possible
I have managed to solve the problem of loading a new map on my Go700 using a Mac. I discovered that Tomtom is incompatible with the Leopad operaying system, despite the protestations of the idiots at Tomtom ,so I reverted to an older Mac using Tiger.
Taking the instructions given to crinold, I tried to erase the disc on the 700 using home 1.5 - and it didn't work. So I went to disc utilities, highlighted and erased the Tomtom disc, and opened home 2,5. After being refused entry several times, like being told to load an already loaded device, I persevered, and managed, slowly, to add the map I had bought for 78 euros. T]One point oif interes is that when I bought the map, they site stated it would cost 63 pounds sterling, but switched it to euros when the invoice arrived. at a rate very favourable to Tomtom - funny, that.
This is sharp practice,probably illegal in many countries,, but, to be honest, dealing with the mysterious Tomtom company is so frustrating, that I don't have the time or inclination to fight them for the money they cheated from me.
How they survive with such an awful product and extremely bad after sales service is hard to understand - perhaps they won't ... we live in hope.
Jul 11, 2008 | Tomtom GO 700 GPS Receiver
I can't figure out how to apply for the products I need to download the map updates for my Tomtom Go 700 (maps are about 7 years old.
You have to download TomTom home, plug your device in via a USB device and TomTom home will start up. You can then download and update your files..
Make sure Tom Tom Home has finished updating your device before you unplug it or you will corrupt the device and render it useless..
Ray
Mar 05, 2008 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 suddedenly the display was stopped
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Nov 27, 2007 | Tomtom GO 700 GPS Receiver
Tomtom go 700
STEP 1
STEP 2
STEP 3
STEP 4
Open TomTom Home
Click on Upate Now.
Oct 20, 2007 | Tomtom GO 700 GPS Receiver
Tomtom 700 turns then turns its self off again
STEP 1
STEP 2
STEP 3
STEP 4
Open TomTom Home
Click on Upate Now.
Sep 29, 2007 | Tomtom GO 700 GPS Receiver
GPS Logo
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
