I have just purchased a smpk2062 and have inserted the disc, but can not find how to install or set-up.
My Computer > CD Drive > MP3set3_81 > Setup.exe
This will install software. If your PC O/S is prior to WinXP you will have to install the drivers first. My Computer > CD Drive > Driver
Set up in the player as a usb device in Setup. Open My Computer, open the drive of your player, then drag and drop the files you want into your player as you would any usb storage device.
Posted on May 05, 2008
Need jsmc850 disc
you might try janome customer service about where to get a
disc
Aug 03, 2012 | Janome Memory Craft 10000
I need to unlock my settings and i can not locate my mac OS X install disc
I am assuming that you don't know the password for the administrator account on the laptop which will allow you to unlock the settings. Unfortunately the only way to change the admin password is to re-install the OS. Seeing that you don't have the disc you will have to purchase one. The Snow Leopard OS disc is available from Amazon.com for just $40 here. Once the disc arrives simply insert the disc and follow through the steps to re-install the OS. More detailed instructions on installing Snow Leopard here. Hope this helps! Please rate my answer if you have time! :)
Aug 23, 2011 | Apple aluminum 13-inch MacBook laptop-...
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
I purchased chessmaster 10th edition and installed to computer when i hit the play button for startup it asks to insert disc 1 i would like to know why this is required when the program is installed ...
i am sorry to give u bad news, game CM is game that need disc to run the game because a lot of stuff that still need to run the program left behind in the disc. it was factory setting.
But u can use alternative way by make the disc to image then run it with daemon tool.
first u need program that can make image file like .iso, .nrg, etc. ( i use nero)
make an image file from CD 1 and CD 2 and save it in computer.
second install program that can make image drive to run image disc (i use daemon tool).
make one image drive then mount the image disc to the drive.
now u can play without real disc. (after finished play the game unmount the image disc)
hope this helpful
Feb 15, 2011 | Ubi Soft Computers & Internet
I just purchased a Hp notebook dv2214us from an auction but everything was wiped clean off the hard drive due to California Law. I completed a self test off the Bios and everything passed. I just recently...
did you go into the bios and change the boot order to boot to the cd rom first? Then it should boot to the disc. Otherwise you may want to use any xp/vista disc do the install dont insert a cd key then once windows boots up then put the disc in and try a recovery.
Thanks,
Lee
Feb 07, 2011 | HP Pavilion dv2214us Notebook
Ok so i have a sylvania SMPK2062 digital media player and i just downloaded some flv. File movies and then downloaded a flv converter and i want to know how to put the video on the mp3
Just get this tool to help you.
1. load your file to Video Sharer
2. choose mp3 format
3. click" convert" button.
Then you will get the right format.
Here is the tool for you: http://www.asharer.com/download-video-sharer
May 20, 2010 | Sylvania SMPK2062 MP3 Player
My IBM Thinkpad T23 needs a set up disc. I purchased it used so do not have one. Help
Use a Windows installation CD, and you will need the product installation code. This code is printed on the Windows label on the bottom of the laptop. Make sure the Windows CD matches the Windows version that is printed on the label.
May 20, 2009 | IBM ThinkPad T23 2647 Notebook
I have just purchased a HP 2133 mini-note. On first installation, installation failed and now it just loops and wont do anything. How can I facilitate first installtion bearing in mind there are no disks...
The majority of these PCs have a recovery partition on the internal hard drive, here is the instructions for using it.
Recovering information using Windows Recovery Environment (WinRE)
Windows Recovery Environment (WinRE) can perform a recovery from either an optional external hard
drive or from recovery discs.
CAUTION: Using Windows Recovery Environment (WinRE) will completely erase hard drive contents
and reformat the hard drive. All files you have created and any software installed on the computer will
be permanently removed. When reformatting is complete, the recovery process will restore the operating
system, as well as the drivers, software, and utilities from the backup used for recovery.
To initiate recovery using WinRE, follow these steps:
NOTE: This process will take several minutes.
1. If possible, back up all personal files.
2. Restart the computer, and then press f8 before the Windows operating system loads.
3. Select Repair your computer.
NOTE: The "Repair your computer" option is displayed only if the WinRE partition is intact. If the
option is not displayed, refer to “Recovering information using a Windows Vista operating system
DVD (purchased separately).”
4. Follow the on-screen instructions.
5. Click Next.
6. Select your user name, type your password (if applicable), and then click OK.
7. If you are using recovery discs, insert the last disc of the recovery disc backup set.
NOTE: Inserting the last disc of the backup set confirms the presence of a valid backup. If you
insert any other disc, the backup will not be recognized.
– or –
If you are using an optional external hard drive, connect it to the computer.
8. Click Windows Complete PC Restore.
9. Follow the on-screen instructions.
this is getting long , so ill will post more steps in comment.....
Nov 20, 2008 | HP Computers & Internet
Purchased a samsung SGH-G600, march 08, unable to connect disc to computer for usege of tranfering photos, music ect fom computer??? when disc is inserted it doesnt seem to upload anywhere and when i...
when you insert the disc in the drive just double click on my computer icon once it is open just right click on the drive that the disc is in and then select autoplay to install and then just followng the steps to install the software on your pc.
Jun 22, 2008 | Samsung Cell Phones
73 people viewed this question
 Grubhead
Grubhead
