Question about Zanussi ZWF1430W Front Load Washer
Model ZWF1437W Flashing Err on front of machine. Think it just needs to be 'reset'. Have tried 'skipping' parts of cycle and unplugging overnight. Nothing seems to be working? Am laothed to hand out 70 euro when I figure it's a minor problem... Help! Antoinette
  • 3 more comments
  • pepsi123 Jul 09, 2008
    My Zanussi ZWF1431 W has a flashing ERR code - but not amount of holding down buttons or switching off and on is working to clear it - HELP!!!!
  • Anonymous Nov 22, 2008
    I also have the flashing ERR, but my counter is stuck on 1hr35m. not even started. tried unplugging, pressing buttons to no avail. says in the manual its a settings problem, but cannot reset it to start again!
    I also have the ERR message. says in manual something about settings, but cannot reset to start again!
  • deeharkin24 Mar 19, 2009
    mine is a zwf 1431s 13 months old im getting err code..its stuck on a cycle and i cant reset it. iv tried holding buttons disconnecting power and still nothing :( pls help
  • Anonymous Apr 18, 2009
    switches on - everyday cotton cycle 140 mins but will just flash Err when any button pressed
    how do i reset it - just want to kick it.
Zanussi ZWF1430W Error E50 please explain
Posted on Feb 16, 2009
    President:
  • 1,294 Answers
Try holding 'end of cycle' signal till the error light goes off.
Posted on Jun 16, 2008
Turn off machine, open the door and start again it worked for me!!!
Posted on Jun 22, 2008
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Electronic controls
You need to replace the control assembly, you find replacement part and schematics here.
You will need to inser your model number.
See here if you need help finding the model number on your appliance.
Oct 11, 2008 | Frigidaire Gallery Supreme Series...
F05 error flashing on my duet washer
"F05" is a Temperature Sensor Error. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Since you've already attempted to reset the washer by leaving it unplugged over night, I'm assuming the problem is genuine and not just a glitch. More commonly, the heat sensor connector comes loose. The link explains how to check. I hope you find this information helpful. Let me know if you still require assistance.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Front loader model#LTF6000E
IS it giving you an error number such E20???
Aug 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Feb 10, 2007 | Frigidaire ATF6000ES Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
777 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
