Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi HDTV I'm having a problem getting the TV to turn on.When I turn it on it shows fuzz and then shuts off and the lamp light goes red.I've only had this TV for about 10 months.Is the lamp bad already or is it another problem?
  • 4,234 Answers
This set should have a 1 year warranty. At this point, do not do anything other than request warranty service. Opening up the unit will void the warranty. If you continue to have problems after the warranty, re-post the problem here.
Dan
Posted on Apr 29, 2008
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Apr 30, 2012 | Mitsubishi WD-57733 57" HDTV
I heard a popping sound in my tv, then it shut off. I turned it back on with no picture, then the green light went off and the red light came on. Is it the lamp?
yes , the lamp went out , u can get a shipone over the internet or buy the original from mitsubishi , i recomment the mitsubishi
Aug 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a 2005 52 inch Mitsu turn it on and it goes to red light
di you replace the power for the lamp in your manul it will show you the lite set for your tv it it will give you i ideal what wrong. i see so with bad power supply or
the balstor go bad to i chang lamp bastor frist. when
the lamp go bad it will show you it the lamp in front of dlp. i hope this help you out.
Dec 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 53 projection TV- won't turn on- Red lamp light is on. Tried to turn the tv on and the lamp light turned amber and we heard the sound of the tv and then it shut off and the red light "lamp"...
unplug the set for over an hour, if the same thing happenes you will need service. Look at the power light, it should be blikning. If you count the # of blinks between pauses it will tell you the problem
Jan 10, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
