Question about DeLonghi Air-To-Air Portable Air Conditioner
Delonghi pinguino classic
Hi how does the water container work i cant see how the water stays in it once the plunger on the bottom has been pressed down and where does the condensation go on this model cheers
  • keim1966 May 09, 2008
    need instructions on delonghi pac152 work where does hose go leaks water
5 Suggested Answers
SOURCE: FE Light
You need drain the water and then function normally.
Posted on Oct 02, 2007
  • 230 Answers
SOURCE: delonghi pinguino k900
Try this link. I do not see a "K900" but maybe it is a start.
http://www.delonghi.com/Int/USA/customer.html
Posted on Jun 16, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: delonghi pinguino pac l90 manual
Here you go!
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Posted on Aug 19, 2008
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
pierre1811
  • 144 Answers
SOURCE: I have lost my manual
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/PINGUINO%20PAC02-_E
Please don't forget to give me a Fixya rating
Posted on Feb 23, 2009
My water container has black fungus ,Icould'nt clean it and I'm afraid to use it.
get a filter from repeatable store.. if i may where's one i recently bought one works good.
Water Treatment
Jul 17, 2016 | DeLonghi Pinguino PAC-700T Air Conditioner
DeLonghi Pinguino PAC-290 - Compressor Won't Come On
Have you tried to descale the unit? I have this unit and it requires descaling often due to the hardness of the water you are using in said unit.
Jul 29, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Exhaust Hose DeLonghi PAC-210U replacement
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Feb 14, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Sep 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
K 900, pinguino
I had the same problem with my Delonghi K900.  I have an extended warrantee for both my Delonghi air conditioners.  It was taken into the shop and discovered that the hose that allows the water to drip into the collecting tank was clogged with dirt and dust. I find it is a good idea to have them cleaned and checked once a year, especially if used often. For under a hundred dollars, I have a warrantee that will last until the year 2010.  Sears offers warrantees for any home appliance, even if it wasn't purchased there. Taking the air conditioner apart yourself can cancel any warrantee on them machine. Hope this helps. Trisha
Jul 27, 2008 | DeLonghi Pinguino PAC-77E Air Conditioner
Jun 19, 2008 | DeLonghi PAC85 Portable Air Conditioner
DeLonghi Pinguino PAC-210
i just opened the back of the unit and byepasted the reset button . the wires on the reset button i toke off and jioned them with a piece of steel connectind the 2 of them together there are 3 of them i just tokk the top 1 and bottom 1 closest to yourself off and jioned them it is working fine and has been since i have done that try that i hope it works for you as it did 4 mine happy sleepin with cool air
Jun 08, 2008 | DeLonghi Pinguino PAC-210 Air Conditioner
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
FE Light
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Air-To-Air Portable Air Conditioner Logo
1,192 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
