Question about Siemens SpeedStream Modem (4100) (SS4100)
Reply from yohwayne
My isp is TADAUST, thank you for your response, I am an IT dumbo.
Have not tried to use voip yet as do not know how to set up, will follow your instructions and keep you posted. Thanks again. Yohwayne
    Novelist:
  • 119 Answers
Dear yohwayne
The ISP service TADAUST is offering this particular plan for broadband.
TAD Super
256 / 64 kbps
12 GB
$29.95
The reason that I am telling you this is because the download speed required for voip service is at least 512/512 kbps (estimate an average 300/300 kbps (30kilobytes/per second) to make it work from your end to the other and backwards) If the speed is not enough the line will suffer cuts and breakouts.
Therefore even if we set this system up it may be too slow to be able to have any functionality for telephony service.
Can you please verify with me that this is the plan you own?
Many regards
EngineerGR
*Please also try to answer at the 1st post you have written as it is impossible to follow any traceability with new posts. :) (Thanks)
Posted on Apr 29, 2008
I cannot connect to wifi always connection failed no response from AP my model unit is gt -s 3653w. I am hoping for your immediate reply thanks.. :)
reset the phone setting then try to connect free wifi after restart your phone .. after that goto to Internet icon then choose setting goto internet profiles . then make your ISP default
Oct 27, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Out going call r not found
Assuming you referring to making outbound VOIP calls, check the DNS servers set on your device. Try chnaging them to your ISP's and that should work.
Please rate if helpful.
Thanks
Mar 18, 2010 | Computers & Internet
Belkin wireless 'N' with Vonage router and cable ISP modem...
Hi, since your Internet source is the ISP modem, you have to connect the cable from it to the yellow connector of Belkin router, then you can connect the VoIP router and computer to any of the ports (connectors) labeled 1-4 , remember to restart clients (PC & VoIP router) to get the new IP from Belkin router.
Nov 07, 2017 | Belkin (F5D8231-4) Wireless Router...
Changing my IP using existing netgear DG834 x 3 modem
Changing IP is automatic when you switch providers. If you're question is actually changing internet connection using existing modem then it's a different story altogether.
First, using Tadaust as your internet requires a username and a password for a dial up connection and a DSL PPPoE connection. You need this information before you can try to connecto Tadaust.
I am not sure if you are trying to make a dial up connection or DSL connection but both can be done on XP by going to Start -> Network Connection -> Create a new connection and then follow the instructions. Almost the same procedure on Vista.
Here's a link to Tadaust support page which might be helpful to you -> http://www.tadaustconnect.org.au/support/
Dec 18, 2008 | Computers & Internet
Patton SIP / VoIP problem behind TZ170W
Please look into the chapter 34 in the guide which you can download from the following link
http://www.sonicwall.com/us/support/230_2749.html
Oct 28, 2008 | SonicWALL TZ 170 Wireless (01SSC5903)...
Reply re tadaust
Ok, then I will be here for everything else you need after contacting them :)
Many regards until then
EngineerGR
Apr 29, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 6520 enabling voip connection to yahoo voice
Dear yohwayne
I am afraid that there are incompatibilities between speedstream 6520 and Voip service. I will need to look at this a little bit further but I think the only workaround is a firmware update. (modified version of the original)
Regards
EngineerGR
CANT SEND FAX THRU VOIP LINE
Make sure baud rate is set to 9600 and error correction mode (ECM) is off. If this does not correct your issue then you may have to contact your provider to adjust your sample rate (packetization). This adjusts the size of the packets and is often a common fix. You may want to run a ping/tracert from command prompt to check for latency and/or packet loss with your ISP. I'm a voip tech and these are the primary fixes for fax issues.
Jan 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Siemens SpeedStream Modem (4100) (SS4100) Logo
230 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
