FixYa.com
Tags:
Whirlpool GU2400XTP Built-in Dishwasher
Philips Whirlpool Integrated Dishwasher
posted by avee2299 on Apr 29, 2008
I can't find the model number on my integrated Philips Whirlpool. The machine is probably 15-17 years old. The pump does not work. What do I do to fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 24, 2008
Not Rated (0)
RevChad
Rank:Master Master
Rating: 78%, 6 votes
Model numbers that are worn or missing are hard to find. When you go to whirlpool's website you might find your dishwasher there, other wise it might not have them listed because it is obsolete.
One place to look is on the panel below your dishwasher door. In some cases it is stuck there, or somewhere else under the dishwasher.
I have seen them inside of the dishwasher housing (under the cabinet between cabinet and dishwasher.
Very rarely will you find the model numbers inside of the dishwasher doors. However according to Whirlpool, if you open your door, you will find a sticker or a riveted plate on the right hand side of the dishwasher's frame, near the seals.
One thing I suggest however once you have discovered the model number, write it down and put it someplace safe.
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Dishwashers problems?
Water Stayed in dishwasher
Could you please advise why... Answer This...
Dishwasher problem
Hi My dishwasher will fill with... Answer This...
my dishwashers not working
hi. when i put it on for a... Answer This...
WHIRLPOOL QUITE PARTNER ii
it just quit. no lights... Answer This...
clean light is blinking
clean light is blinking. Manual... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
