TV will turn on for 2 seconds then power off - is this fixable?
  • 4,234 Answers
Sure its fixable. If you can provide the make and model and any symptoms, we should be able to guide you to a solution.
Thanks,
Dan
Posted on Apr 29, 2008
My 19v712m manga box tv goes black
The steady blue LED merely indicates that power is getting to your TV. The internal power supply may have failed
May 15, 2013 | Televison & Video
Why does my tv turn off by it's self after a few
Either a power board problem or something in the set is pulling the power voltages down---if under 26 inches it may not be fixable.
Mar 19, 2012 | Emerson Televison & Video
My proscan TV was working fine. then the video went and now no audio.. it lights up briefly when u turn on. then screen goes dark.. is this fixable or better to get a new tv..It is only 3 years old
I believe it's fixable! Take a look on your video and audio cables (behind the TV, the red, yellow and white ones). They must have a problem. Already happened to me!
I hope I've helped...
Feb 14, 2011 | Proscan 42LA45H 42 in. LCD TV
52'' Sony Bravia will not turn on
Its fixable problem like power supply board replacement will solve the problem.
Unplug tv from wall socket for couple of minutes, replug back in and turn it On.
If problem still exist then most likely power supply got fired and will be replaced, local tv repair shop will help you to replace power supply board.
Thanks.
May 02, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
Akai plasma tv won't stay on.
Replace main controller PCB. PN E3761-058010-2
Apr 05, 2009 | Akai PDP4273M Television
TV struck by lightning
Looks like the flyback (high voltage transformer and probably the majority of the power board is kaput. It would be cheaper and probably worth your while to invest in a new TV rather than try to fix this one..
May 30, 2008 | Sharp 32C-240 32" TV
Screen has turned a blue tint after turning itself off
I will not bore you with advice which you cannot follow. (90 % probability, looks like the Blue Signal Video Output Transistor has become faulty). This is a very simple "fixable' problem for a Professional Technician. Should not take more than 15-20 minutes.Nothing you can do. Call for Professional help.
Jul 26, 2006 | Toshiba 32A33 32" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
