Canon L120 fax machine - Set document - Office Equipment & Supplies
Thank you but I've solved the problem by pressing all available keys! Does make sense when nothing else works..
Posted on Apr 30, 2008
The heads on my fax machine need cleaning how do i do it
Your fax machine (L120) use dry toner and not ink cartridges, so it doesn't have printhead. If the copies are dirty or bad but received faxes and printed documents are OK, then You have to clean the scanner unit (it's above the plain paper storage and can be opened with small handle).
Hope this was helpful
Aug 28, 2015 | Canon i-SENSYS FAX-L120 Laser Fax Machine...
How do i receive a receipt for something Ive faxed ? Cannon L160/L140
under user mode, choose data registration, report settings and under TX report set YES. Then after each fax you get transmission report with image of document you've sent.
Aug 04, 2011 | Canon L120 Fax Laser Printer
I have lost instruction manual. How do I 'copy' on a canon FAX-L120
1-Load the document face up in the ADF/Tray
2-Enter the copy mode by pressing Copy Button
3-Enter Quality
4-Press Start
For any further information/ clarification please refer to Chapter 6, Page 80 & 81 for the Canon i-SENSYS FAX-L120 Manual.
Save the Manual for Future reference
Hope it helps! Good Luck!
Mar 11, 2011 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
What does coms error 00E8 mean?
Canon FAXPHONE L120 Laser Printer Please follow the instruction as given below may this will help u any
Error Codes
An error code is a four-digit code displayed on the LCD or in the bottom row of a TX Result Report or an RX Result Report when an error occurs.
See the table below for individual error codes.
Error Code Description Action 0001 The sender may not be using a G3 fax machine. Make sure the sender's machine is compatible with your machine 0070 Reception was manually canceled on the machine. Ask the sender to resend the document if necessary. 0071 The machine's memory is full. Print, send, or delete any documents stored in memory. 0080 The recipient's machine did not respond within 35 seconds. Resend the document. Ask the other party to check their machine. If you are making an overseas call, add a pause to the number. 008D The recipient's machine has run out of paper. Ask the recipient to make sure that paper is loaded in their machine. 00A0 Transmission was manually canceled on the machine. Resend the document if necessary. 00A1 There is a document jam. Clear the document jam. 00FF All redialing attempts have failed. Check if the recipient's number is correct or the telephone cable is properly connected, and try again.
Aug 18, 2010 | Canon L120 Fax Laser Printer
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
How to I delete my fax machine memory? It says Memory Full and I am not able to send a fax. Please help me. Thank You My fax machine model is Canon FAX L120
Go to Control Panel>Double click of Printer & faxes >It will open up a window you need to delete all tasks from that. If it still doesnt help contact Canon people for further assistance :
Jan 08, 2009 | Canon L120 Fax Laser Printer
Put in number press the green button to send the fax and it comes up with Memory Set Doc flashing but wont send the fax.
try sending manually
to do so
load a document---->press hook----->dial the number----->when you hear a fax tone press start.
Aug 05, 2008 | Canon L120 Fax Laser Printer
Canon L120 Fax machine
You have to make sure that the document release lever is fully down.
Jun 01, 2007 | Canon L120 Fax Laser Printer
Canon Fax L120/L100
press menu and then # goto service mode. Select the clear data function.
Clear all the memory, dRAM and counter.I hope it will work for you.
May 10, 2007 | Canon L120 Fax Laser Printer
138 people viewed this question
