Question about LG Cell Phones
LG TU500 - Mobile phone only rings for 15 seconds when someone calls it before terminating the call if not answered. How do you increase the ring duration so that it rings for longer to give you more time to get to the phone?
  • Anonymous Jul 07, 2008
    How do you change the amount of rings before voicemail picks up?
  • Anonymous Mar 29, 2014
    Incoming phone calls ring for only 15 seconds, this gives no time to locate phone let alone operate it, how do I increase the ring time (a lot)
For a Telstra handset type into your phone.....
Posted on May 31, 2008
My phone won't ring
If you are using Android phone you need to make sure that the ring-tone volume is not muted. Just goto setting and sound and then increase all the volume, sometime even if the phone is not in silent mode it won't ring due to Android sound settings . You can also use the volume rocker key to increase the ring tone volume. Just in case also change the ring-tone as well in case if the ring tone file is corrupt. Now try ringing your phone from another phone and see if that works. If it still doesn't work, just turn off your phone and take the battery out for 10 seconds and put it back. Try ringing it again. If nothing works, there might be problem with your built in speakers. And you need to contact the manufacturer.
It would be better if you could tell your phone make, model and mobile operating system name and version, to help you further.
Dec 27, 2013 | T-Mobile Concord
Setting the number of rings before answering machine kicks in
Here is the link to the user manual; Check page 19 - you can set the answer rings from 2 to 7 Hope this helps :)
Jun 19, 2007 | Panasonic KX TC1501 Cordless Phone
I have the panasonic phone but when someone called me after 3 rings it goes on answering machine. i wanted to make it longer at least after 5 ring. please help me with any suggestion.
You can set your ring time to 5, 10, 15, 20, 25 or 30 seconds.
  • Tap **61*121*11* into your phone as if you're making a call.
  • Next enter a time between 5 and 30 (the number of seconds in multiples of 5)
  • Press # and then the call button. Don't put the phone to your ear - just look at the display until you see a message confirming your ring time has been set.
For example, **61*121*11*25# followed by the call button would set your ring time to 25 seconds.
Jun 11, 2011 | Computers & Internet
Where is the volume control on LG KU990?
its the camera ring thingy outside the lens on the back of your phone, you can turn counter clockwise to increase the volume (might be the other way I'm not sure)
Aug 10, 2009 | LG KU990 Viewty
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
LG KF310 ring time too short
change the ring tone some ringtones are short especially the ones that come stock on the phone
Apr 03, 2009 | LG KF310 Cellular Phone
Alarm and ringtones only occassionally go off - LG TU500 (CU500)
i know theres a factory reset in the phones test mode. to get to it press 277634#*# on the phones main screen. not sure if it will help you to much but its worth a try. let me know if it works
Dec 22, 2008 | LG CU500 Cellular Phone
LG Tu500(cu500) Ring tones problem
actually there is, use a program called Goldwave. open the song u want, trim it to 20-30secs, and save it as an Mp3, 44100hz 48Kpbs mono, then save it to the memory card. using the phone, goto the memory card, select the song you just edited. and set as ringtone. Done.
and yes this does work as i've currently got Sum 41 - With Me as my ringtone
Apr 07, 2008 | LG CU500 Cellular Phone
My own musics to ring tunes, LG TU500 cell phone?
go to ur gallery,highlyt the music that u want 2be ur ring tune,then press option,then find the use tone,then select 'use as a ringing tone'..
Apr 07, 2008 | Cell Phones
Change msg tone to a customized tone
use a program called bitpim and get the usb driver for the "tu500" its the same phone but its just an Australian region phone item name and then you can change the internal sounds on the phone like message tones and all that and get rid of the annoying confirmation sound. if you need more help with this try googling "LG cu500 forums" you should get an lg forum website with ppl that have that problem and they list the steps there cuz that how i did mean how that helps
Nov 06, 2007 | LG CU500 Cellular Phone
Cell Phones Logo
192 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
