Question about Nokia N73 Cellular Phone
Turn off during software update
I updated my n 73 software but its shut off its self and can:t turn on again..
  • 3 more comments
  • eliisa Jun 05, 2008
    I have the same issue, it turned itself off and now all i get is a lit up black screen.
  • dranandnema1 Jun 14, 2008
    yes, i have the same problem.
    "i updated my N73 software but its shut off its self and can't turn on again..."
  • Anonymous Mar 29, 2009
    me too facing the same problem. Can anyone provide us how to resolve this ?
  • Anonymous Apr 29, 2009
    sir, i updated my Nokia N73 software but its shut off its self and can't turn on again..
  • amit_xyz1175 Apr 29, 2009
    how to repair n73 while updating firmware version it switch off?
Sir, i updated my Nokia N73 software but its shut off its self and can't turn on again...
Posted on Jun 14, 2008
How to repair n73 while updating firmware version it switch off?
Posted on Apr 29, 2009
My mobile during software update stopped working and after switching off it can not be turned on
This are the guidelines of proper updating your phone firmware.
* Need a Good software for updating your phone. * Be sure battery is fully charge.you may insert charger for backing up the power * stable internet is required * Usb cable is good
If one of the above fails to compromised,expect failure in updating and phone shut down.you can not repeat the procedure because the software require the phone in normal mode.it will not recognized the phone when it is dead.
To recover your phone,must need a gsmgadget,f-bus cable and a good firmware making phone live again.mobile service shop have this tool so better bring it for sure.
Jul 31, 2011 | Nokia N70 Cellular Phone
How long should the process take - the "download mode"
Download mode is when a techincian is programing the copier with new or updated system software. It is not a self serving update application. The machine will sit until it gets that flash done but someone on site. To get out of this mode shut the machine off then turn on again. Hope this is helpful.
Jun 17, 2011 | Canon imageRUNNER 5000 Copier
I was trying to update my N73's firmware, but then
hi for this follow these steps :-
1. full charge your phone 2. connect your phone with pc through data cable. 3. and then run nokia software updater and wait for 5 to 10 minutes
if u dont have nokia updater then click on this site and download http://www.nokia.co.in/get-support-and-software/download-software/device-software-update
May 12, 2010 | Cell Phones
Software update -N73's firmware
There in nokia software updater they strictily warned for Do not disconnect mobile device from pc while update in progress it will be reposible for damage to phone.
Now you must have to contact nokia care & re-Install phone software.
Thanks.
Oct 14, 2009 | Nokia Cell Phones
When i turn on my sansa its said sandisk , then raspody sansa then it shut down by itsself , the turn on by its self and its repeats over and over again.
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Jun 01, 2009 | SanDisk Sansa e250 MP3 Player
N 73 Stuck.
If you could not complete your firmware installation,Please re install your phone with the same firmware using Nokia Software updater.
Feb 13, 2009 | Nokia N73 Cellular Phone
N 73
If it's a signal strength problem, it's more likely to be your Network Service Provider than your phone. However your internal aerial might be faulty.
You could try a restore to factory settings, but I don't think it will change anything.
Updating the Firmware might help.
-_-_-_-
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 01, 2008 | Nokia N73 Cellular Phone
Is it really dying?
It's possible the battery is dead, but the phone may also be too full of old files/msgs/pics/applications/games etc... the phone needs a certain amount of memory to function.
Try another battery or a new one, if it starts do an update of the phone software (firmware). You can do this yourself, but it may be better left to a repair/sales shop.
You need to download the latest Samsung PC Studio to do an update on your phone.
WARNING
“I can resist anything but temptation.”
Apr 25, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Phone dead
DO NOT-----DO NOT---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
If the PC freezes during an update, you're up the creek without a paddle...
Jan 05, 2008 | Nokia N73 Cellular Phone
N73 software update - phone not working
Jan 04, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
441 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
