DAB RADIO MATSUI MATCR 515D- ILLUMINATED TIME/STATION DISAPPEARED - NO RECEPTION - MUSH CAN BE HEARD IN SPEAKER
It is possible for the display to be set so low that it is not illuminated at all. With the radio off (i.e. the set must be in standby), press and hold TUNE+ to raise the brightness level.
If this gets the display back, you may be able to see what has happened to the tuning. e.g. check whether the tuner is set to FM or DAB etc.
Posted on Sep 02, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
May 26, 2016 | Audio Players & Recorders
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
I am looking for a user manual for a Matsui DAB/FM Alarm Clock Radio, MATCR 515D. Preferably free. Thanks!
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 24, 2011 | Audio Players & Recorders
Dual xhd6425 Reception Problems
My XHD6425 seems to be very inconsistent... Sometimes I get okay reception, other times I get terrible reception (much worse than my original stock Ford radio). The reception problems are more noticeable on stations that are more than 30 miles away or so.
Perhaps oddest of all, I've sometimes had it bounce back and forth between two stations (like if you are driving and in the middle of nowhere, half way between two stations), even in areas where I know should be getting good reception on one station and had never heard of the other other station before.
If you've figured anything out, please let me know.
Jan 16, 2010 | Dual Electronics XHD6425 Car CD/ MP3...
I purchased a new Matsui DAB Portable Radio MATDR100 yesterday from ebay, i was really pleased with it but today, the reception went blurry and then it cut off suddenly. There is still power going into it...
matsui was specialy made for curry's if you ring your local branch and ask for the phone number of there service dept and ring them i have found them helpfull in the past as only they have service manuals .sorry but i can't find the number
Jun 13, 2009 | Electronics - Others
Setting the reset stations on a DAB radio
I used lateral thinking! looked at the instructions for my other matsui DAB radio and worked it out from there. With this Ferguson model you have to find the station you want manually and then press one of the preset buttons (it only has 4 but these are enough for me)
Jan 06, 2009 | Audio Players & Recorders
Radio reception problem
keep the antenna away from the metal contact.
Jan 01, 2009 | RCA RP7887 High-Performance Super Radio
How to preset favourite dab stations on matsui dr100 i have no instructions
This budget radio from Matsui allows you to enjoy the wide range of benefits of DAB digital radio for a very affordable price. The R100 is powered from the mains and features stereo speakers to allow you to really enjoy the clarity of digital radio.
Digital radio offers more station choice in more places, meaning that digital radio has something for everyone. DAB even has easy tuning, therefore you no longer have to scroll though numbers to find the exact frequency and you no longer have to remember the frequency numbers as with DAB you scroll through station names.
hope this may help;
DON'T FORGET TO RATE;
Aug 18, 2008 | Audio Players & Recorders
253 people viewed this question
 Grubhead
Grubhead
