Question about Acer Aspire 5610-4648 Notebook
Acer laptop stuck on Acer welcome screen.
Well I had it on last night, and went to bed. When I woke up the computer was off, but I'm used to that because sometimes it would shut down if the battery is low..but it wasnt. I press the power button, and now, it's stuck on the Acer screen, where it has that load bar at the bottom right corner. I tried pressing power again and also taking the battery out. I pressed F2 too, but it just says "Plese wait..." on the screen..>_<
  • alex_gilboa May 03, 2008
    I have the same problem after creation one more partition with Windows Vista Hard Drive Manager
  • Dave117
    Dave117 May 11, 2010
    I guess pressing F2 is to access bios?? If not, maybe you shud try del key or whatever gets you into bios & reset to default. If this fails I think there will be a battery backup for bios that you reset.. But not sure where it's located on this pc. Just a thought, maybe worth chasing up. Another thought is to try a dvd boot disk in the drive or even a Linux live boot disk to prove it's hard drive related..? As above, just ideas. Good Luck.
  • 472 Answers
Remove the hard drive and try it again, if no change also remove the DVD rom drive.
The computer is trying to access the drives, but failing and will just sit there and keep trying until it either succeeds or eventually fails & then will report it.
The fact it has hung like this would indicate the hard drive controller board has failed though and is no longer reporting back to the bios when it is queried.
If this gets you past that point, then before you take a hammer to the drive, reseat it back into the slot firmly and try it again.
Posted on Apr 29, 2008
When I boot my Acer Aspire One, I get a black screen that says: (line 1) check cable connection...! (line 2) pxe-e63: error while initializing the NIC (line 3) pxe-m0f: exiting Intel PXE ROM. (line
Seems your graphic card is fry.But you cant do a test to confirm it.Just plug anohter monitor to the VGA slot and powerup the PC.Test if still no screen that will confirm the problem.
Apr 12, 2013 | Computers & Internet
Monitor dead
Check your power cables properly and make sure it is attached. Check your power button, maybe you have pressed the wrong one.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Screen went blank and orange light is on
fiona_sheeha, If ACER warranty service not an option, then unit will need local tech to troubleshoot unit's power supply/inverter circuit for possible COMMON and repairable printed circuit board fix. You must read more of my fixya profile and visit the web links you find there so you will know and understand what ALL your options are!!! Some units require less than $5 in parts to refurbish them to working status. Your "cold-cathode-fluorescent-lamp" backlit LCD monitor isn't any different than any other brand of monitor in it's basic operating principles!! I hope this helps. 12fixlouie
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
My coffee pot died during the night
It had nothing to do with the coffee pot. I blew a breaker!
Aug 30, 2009 | GE Coffee Makers & Espresso Machines
Phone doesn't turn on.
You should not allow the battery to fully drain,it will die sooner.
Remove the battery for 5mins, replace,and then try and turn on the phone.
Apr 07, 2009 | Motorola Mobility RAZR V3
Archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
Apr 25, 2008 | Archos 404 Digital Media Player
Stuck on logo screen
I hate to tell you, but that is bad news. But before we jump to any conclusions, first open up the computer and look for the BIOS reset jumper on the motherboard, if you find it switch it to clear CMOS for around 20-30 seconds and then put it back on normal and see if it boots. If it doesn't, there isn't much more we can do, as your motherboard most likely decided to keel over and die.
Apr 09, 2008 | Medion MD-1704 PC Desktop
Acer Aspire 5610-4648 Notebook Logo
398 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
