Sir/Mam Please try by providing this code 12345. Because 12345 is the default code that the Nokia company has provided. In case if you had changed it then please provide the code that you had changed it. When it's OK. Press menu>settings>Phone>Security Keyguard>Choose Off (When security code is dialog box isshown to you there type or put 12345 or you can provide the code that you had set which means that you had changed it from the company default code 12345)
Switch off the Nokia 1200 phone. Remove the battery for 30 minutes.Reinsert the battery and switch on the Nokia 1200 phone.Enter the default code 12345 or 00000.Your Nokia 1200 phone will be unlocked.
When you want to restore the factory setting on your phone, the code it asks for is not a restore factory code, but your phone's security code. So when prompted for the security code, enter the default code - 12345. But if you had initially changed this code, then you are to enter your new code when you are prompted for it. Hope that helps. Success.
need to notify dealer radio codes are part of vehicle security most dealers dont charge for code but will need radio number ,vin number and usually are asked to come in with id
If you have not changed the security code, then try the default of 12345. if you have changed and forgotten then you will have to get the firmware re-installed from Nokia Care.
Your phone’s four-digit lock/unlock code is originally set to 1234. The six-digit security code is originally set to 000000.
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the last four digits of your phone number. If that doesn’t work, press and enter your six-digit security code instead. .
You can access the phone using the PUK code provided in your phone. once you access it, i dont think you can change the code as you dont know the current one but surely can disable it..!!
