Question about Sharp AR-507 Copier
AR507 SHARP I fix the the developer shaft and bearing but still the developer is pouring out.What could be the problem? Samuel
  • kinyash Jun 17, 2008
    Thanks Bubbabear64 that is the problem.Would know anyone who could be stocking this part?
  • Sharp Master
  • 2,794 Answers
It could be the seal that goes around the shaft. You might need a whole new toner/developer unit.
Posted on Jun 14, 2008
Wpc555mp3 manual, please
washing machines are lo-tech and a doddle to fix - but not necessarily inexpensive.
Many failures are main bearing due to persistent overloading (could that be your beloved?). Get a replacement bearing for a few pounds from Improvised bearing extraction is another subject, but if it's knackered then something about a piece of wood+hammer or a car jack+attachments (steel wire or steel brackets). Clean the shaft, use a silicone or ptfe spray to ease on the new one - job done. If the bearing rotates on shaft peen it fixed with a couple of sharp knocks with a centre punch.
Broken belts - no further advice needed.
Motors : may be cheaper to replace machine unless you can locate a rewind facility - these may still exist in developing nations but not Blighty. Local amenity tip may have one?
Controller: Replacement with new - see 'motor' - or eBay for a used one. Solid state controllers - you need a triac/SCR/MOSFET/w.h.y. Manufacturers conveniently grind off the type number, so you'll need a mate who works for one of the multinational semiconductor manufacturers.
Other bits and bobs like rubber seals, door hinge, etc are trivial and widely available from third party suppliers as well as s/h sources.
Nov 26, 2012 | Televison & Video
A brod white patch on centre con copy Sharp AR 163
check the developer in the developing unit maybe the developer is empty,then also check the charging assembly maybe its pour of toner just try to clean
Sep 03, 2010 | Sharp AR 201 Copier
I need the reset finisher code for ar507
If finisher works no need for reset.disconnect finisher cord and use it
Apr 09, 2010 | Sharp AR-507 Copier
This 5 consecutive jams in fuser. Clear all jams and then enter P- interrupt-C-interrupt-14-start and then follow prompts.
CA to exit at the end
Oct 06, 2009 | Sharp Office Equipment & Supplies
I need document feeder tray & document feeder unit for Sharp AR507
The RSPF (Reversing Single Page Feed) document feeder unit doesn't have a single part designation for ordering the entire unit. It's a standard item with the AR507 (meaning it's considered a part of the full machine).
If you want to order individual parts of the document feeder, you can contact Sharp via their website.
Sep 15, 2009 | Sharp Office Equipment & Supplies
How do I put developer in a ar208s sharp copier
The developer comes in a bag and is poured into the developer unit which is the unit that the toner unit slides into. You should have a screw to loosen to slide the developer unit out. It has a silver magnetic roller that will be visible. There will be an open slot on top of this unit to carefully pour the developer contents into keeping it level. Reinstall and secure the holding screw. install your toner and test. I hope that this helps. Usually a service tech will set this up for you before you see it.
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
How to put developer(black) into copier
1. Open the front panel
2. Pull out the toner cartridge
3. Unscrew the blue screw that fixed the developing unit to machine base
4. Pull out the developing unit
5. Unscrew two screws above the developing unit and one in the bottom middle.
6. Take out the toner cartridge housing
7. Pour the developer
8. Reverse these steps to re assembly the developing unit.
9. Turn on the machine
10. Execute developer calibration, follow these steps :
[#] [INTERUPT] [C] [INTERUPT] [25] [START] [2] [START]
11. Wait until the calibration finished and
12 Press [CA]
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to chande the developer
you take the drum out, then unscrew the developer (it should be a greenish screw), it should slide out, empty the developer out, take bag of new developer shake it up real good... then pour evenly into developer unit, while turning the mag roller... reinstall..
Nov 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Firmware upgrade
What version do you have now?
Here is the newest version posted on SharpNet:
Version H2.40 contains the following modifications: 1. H5-01 error detection changed from 3 successive errors to 5. (POD1) 2. “H3” errors eliminated when ICU detects E7-00 error.(PCU processing change) 3. Image rotate information retained during paper-out condition by specifying use of manual feed tray. 4. If L3-00 or L1-00 errors occur after upgrade, TC 26-59 settings must be changed. Refer to technical bulletin AR-337-001 R for instructions. AR507.EXE Contains all the files needed to upgrade the AR287/AR337 copiers using a PC, SCSI adapter, and 7 series Black & White Imager. (AR287 ~ AR507) Refer to Technical Bulletin AR-505-001. AR507.EXE contains the following files – ICU_H2_40.mot, ICU_H2_40.fd, PCU_H2_40.mot, PCU_H2_40.fd, OPE_H2_40.mot, OPE_H2_40.fd, and Flash5.1.exe
The firmware upgrade on these "toner bombs" is no walk in the park but I can walk you through it and provide the bin files and software. contact me at double-u double-udouble-u dot brianbell dot net for more information.
Dec 26, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-507 Copier Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
