Question about Acer Aspire 5100 Notebook
Modem not Working
G'day, I was on the internet last night then disconnected. Forgot to do something, went to connect again but a redial message came up & started to count down. I have restarted my computer several times & tried to connect several times but with no success. Show's error 797. Any idea?
  • 652 Answers
This error cause:
  1. Incorrect Windows connection settings.
  2. An incorrectly configured modem.
  3. A corrupt dialer.
  4. Out of date modem firmware.
But before trying anything chech your modem is ok and driver is installed correctly.
Click here, there is a detail help how to fix your problem.
Please post your feed-back.
Thanks
Iqbal
Posted on Apr 29, 2008
Internet problems, I can connect, codes 814
Reset the Modem Router disconnect the power +Hold the small button by 30 seconds and connect again.
Try again.
Restore the machine go to control panel, and look for the utility restore the system, and use the last day that you know was working good.
You must sure the internet connect had been o.k or call to the provider for to see if there are problem in your area.
God bless you
Oct 22, 2013 | Dell Inspiron 530s Desktop Computer
Lenovo G550 running Windows 7 won't connect to internet. "Default gateway is not available" message displays. I have 4 Vista computers using wireless connections all functioning fine, but this...
Hello
Wow youve done almost everything here.How about the firewall? is it blocking any connections?
Next,Go to control panel,network and sharing center.Look and see if the pc or laptop in question is on the same network,meaning home or public.
Set all your machines to the same network.Either home or public.I do know this has been a win 7 problem.
Mar 11, 2011 | Lenovo G550-29583AU Notebook
I've got a Linksys WRT160N V2 router that stopped connecting to my modem last night. If I plug my computer directly into the modem, I can get Internet access, but if I plug the router into the computer and...
I had the same problem and found that the port was damaged and change to another port and work fine but after a few days working file it drops back again and no internet again. Tried all the other ports and no result. I found out that something is going wrong with a part in the router and when it heats up the problem repeat.
So my solution is Buy another router and my choice went to:
TP-Link TL-WR1043ND
Dec 16, 2010 | Linksys WRT160N Wireless Router
Internet going off VERY frequently
1. Firmware update may be required for the Router.
2. check your firewall settings and the Wireless configuration in the router.
3. You may have to allow the MAC address for the device that you are trying to connect with to have permission to connect to the network.
4. Verify IP for the the PC ( this is done in the DOS window) at the DOS prompt type "ipconfig /all" this will bring up the network report as to what is and what is not connected.
5. Unplug router and modem from the AC.
6. Reboot the PC.
7. Window is totally different from the router firmware updates.
Windows is downloading it security and web update when you see the prompt. This has nothing to do with the router.
Jun 18, 2010 | 2wire (1000-400108-001) Router
I have a Westell DSL modem & a D-Link DIR-625 wireless router. Everything has worked fine for years but a few days ago the Internet connection went down. I contacted AT&T for support. During the...
you need to configure the dsl modem to be on bridge mode after you did it successfully. that is the time you configure your d-link for you to connect to the internet.
call first your ISP to configure the modem to Bridge mode after that call your manufacturer of the dlink for them to configure your connection
Jun 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
Every morning I can't connect to the internet without swiching the modem off the back on despite all the lights being on. I can leave the computer on all day connected to the internet and everything is...
Change the security settings of your modem to WAPBY GETTING IN TOUCH with your ISP vendor.May be some one else in your neighbourhood is able to access the internet by connecting to your Modem.
Oct 10, 2009 | NetComm NB750 Router
Broadband doesn't work since installed AVG 8.5
check the avg firewall. it may be blocking your modem.
Apr 29, 2009 | Computers & Internet
NOT WORKING AFTER POWER OUTAGE.
are u getting all the lights on the router?if yes then connect the router with modem n if its wireless then turn off all three devices
then turn modem on first n wait till the lights on the modem get settelled,then turn the router back on n the computer,n check whether the computer is picking the wireless or not,if yes try the
internet.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
Nokia 5200 Modem Is not responding
first of alll go to device manger in pc and then go to modems section there u can find ur phone modem listed there . then right click ur phone modem and select properties then go to advanced tab . there u can find a column named as extra initialization commands if something is wrtten inside that column delete it and select ok . then clear cache of ur cell phone . restart ur phone and pc and try
Nov 11, 2007 | Nokia 5200 Cellular Phone
NEW BELKIN WI FI CABLE ROUTER NOT WORKING AFTER 4 DAYS OF USAGE
I would try a hard reset of the router to reinstall the original settings. Then reconfigure and test again. If ther is no change then as you probably suspect the router has failed. Let us know if you have any other questions and please don't forget to rate this posting.
Feb 06, 2007 | Belkin Wireless Cable/DSL Gateway Router
Acer Aspire 5100 Notebook Logo
139 people viewed this question
Brian Sullivan
Brian Sullivan
