Question about Microwave Ovens
Power cut out during operation. No illumination of timer or internal light. Tried at other sockets but nothing.
Try checking all fuses they should be easy to find once you take the outer cover off replace any blown ones they look similar to a lightbolb for a car if the wir inside is broken they are blown
Posted on Apr 29, 2008
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Will not turn on.
When you stated no power that there are no lights or fans that can be made to operate, yet fuse checks good.
On some units, the fuseholder will be mounted to a small pc board. Remove the screw that secures this board and inspect the underside for bad connections. What happens is power enters board through power cord but power is not provided to rest of oven.
Dec 13, 2017 | GE JVM1640 Microwave Oven
Westinghouse wmg281sf microwave Microwave (mw) less than 6 months old and after selecting start the mw makes a noise that seems to come from the light and during operation impedes the power source to the...
Hello mbz... Since the operation is impeded, the problem is more than the light bulb. This unit has an internal short, and should be under warranty for the first year. Return it. Joe
Thanks for choosing Fixya!
Dec 16, 2010 | Westinghouse Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Display and heating problems
Problem #2 is a bad door switch or door switch mount.
Problem #1 is a trouble with the control unit / display.
The avergae do-it-yourselfer can replace a door switch if he follows the proper safety and repair advice.
We repair control units on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
When you get to our site, do a Ctrl-F search for R630.
We also have the entrie service manual for these on our site.
Oct 31, 2007 | Sharp R-630D Microwave Oven
Bosch hmt9626 gb 1000w microwave cuts out after 20secs
ur mag netron is faulty the reason for cutting out is thermal cutout switch change magnetron
Jan 20, 2007 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
