Question about AT&T Blackberry Curve 8300 Smartphone
Blackberry 8310 Problem is the BB is in a continuous startup?reset loop Red light on hourglass timer comes up nothing then the same gain and again any ideas???
  • 1 more comment
  • dabarros May 05, 2008
    I have the same problem.
  • rital Jun 21, 2008
    Suddendly , my BB Curve 8310 went in a continuous startup / reset loop :
    red light on , screen lights up , hourglass timer comes up ,and stays on for 1 or 2 seconds , then screen becomes blacks again ....after a few seconds red light on ... and the loop start again and again .
    No way to access the menu .
    I removed the battery and the sim card but nothing changes , as soon as a put battery back the loop starts again .
    How can I stop it ?
  • Anonymous Oct 10, 2008
    Same exact problem
I had this issue and found that a system restore restored the BB back to the factory settings. I have seen an improvment but, we'll see.
Settings --> Options --> Security Options --> General Settings --> "from the Menu Button click on "wipe Handheld""
and wait!
Posted on May 28, 2008
My bb screen is all white and I cannot turn it off as well. Please help
Hello
First of all what you need to do is to perform a reset on your BB by hitting ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
ALT+RIGHT SHIFT+DEL can be used for continuous hourglass issues, JVM Error 200 "White Screen" to name a few.
If that does not work then you should perform a battery pull by just pulling out the battery out of the phone while it is on this is also a reset option.
Go to your service providers website, download the software from there, and then install it on your pc. Once done, delete the vendor.alx(xml file) file, open Desktop Manager (DM), connect the BlackBerry, and follow instructions
Apr 20, 2011 | Computers & Internet
BB 8320
Do you have a SIM card installed on this phone? If not, try inserting one properly and correctly.
Secondly, how good is your battery? Try charging your battery fully. Also, it should be a good battery with some life left in it.
Finally, if you have a valid and authenticated SIM card installed, and your battery is good and fully charged, the next thing to do is remove the battery, wait for about 60-90 seconds, reinsert battery and unit should boot up fine after about 2-5 minutes. Hope this helps.
Aug 20, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Curve with white screen with hourglass and red light on
If the flipping hourglass stays for longer than 2 min our Blackberry may just need a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Aug 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8310 fatal error during backup
I would connect the device to a PC and update the OS using Desktop Manager. If you recently installed any application, I would uninstall it as this may cause this type of behavior.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Power cycles but never starts
You said you'd tried a reset - both types!?
Hold these keys down simultaenously - ALT+RIGHT SHIFT(CAP)+DELETE
Power back on.
If that doesn't work - try a double soft, where you follow the above, wait until you have a blank screen and then repeat - You should get another blank screen followed by the hourglass.
Apr 19, 2009 | RIM BlackBerry 8820 Smartphone
JVM error 102 on the blackberry
1. Connect your BB to the computer.
2. Run JL_Cmder (JAVA commander, it’s a freeware, google it and download latest one)
3. Choose option 5, wipe the device. This will delete all files - OS and data - from your BB. The BB screen will show JVM Error 507. This means the BB has no files installed.
4. Using Desktop Manager, reinstall your software. When you run the Application Loader, check all the available boxes.
5. When this process completes, restore your most recent
backup file if you have taken in the past!
You should be back to normal, with the exception of having 3rd party apps.
let me know if any problem or have any other questions.
thanks.
Regards,
AJoshi
Mar 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve won't turn on...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
Mar 19, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 8310
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Aug 09, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
AT&T Blackberry Curve 8300 Smartphone Logo
169 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
