Question about Dell 962 Photo All-In-One InkJet Printer
Scanning my scanner makes lines on my pictures or documents, how do you get inside to clean the glass and what do you clean it with,
  • 1 more comment
  • hanketta May 01, 2008
    I cleaned the glass on the outside its on the inside but Its inclosed and I tried to get inside and couldn't get to the glass
    my scanner has dark marks on pictures and text that I scan. I cleaned the glass on top but how do I clean inside its very inclosed. what do I clean it with
    I will try the calbriation when I get time but I just newly loaded this printer to my new pc and I had to run the disc so I doubt that will make a difference. but I am willing to try. I don't want to close this out until I am sure I can't fix it. thank you for your advise.
    President:
  • 2,712 Answers
You may have to recalibrate the machine.
1. Go to the calibration utility in your scanner software and open it. 2. Place a normal printed A4 size sheet (use only text without pictures or colour) onto the glass top.
3. Close the cover , making sure that there is no light entering the scanning surface due to a loose cover, etc.
4. Start the calibration tool.
Problem should be solved.
I don't think this is a problem with the glass, unless you can actually SEE visible streaks of dirt/grime on it. Besides, it is not recommended to remove the glass covering. Clean the surface side by all means, if you need to.
If all else fails, try reinstalling the driver for the scanner.
Hope that helps!
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 01, 2008
  • Swilin Sampson
    Swilin Sampson May 01, 2008
    Just checking to see if your issue has been resolved… If
    please close the ticket with a FixYa! rating under my solution.
    I
    Should you have any further questions, please feel free to
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    No problem, hanketta. Take your time to resolve this this issue. We are here at your service :)
    Remember, any further questions, post back. PLEASE don't assign a rating till you are satisfied about the resolution of your issue...
    Cheers,
    IrishDruid
    Genius:
  • 1,447 Answers
Cant suggest for you to open up the scanner by yourself, you might cause more damages on the printer itself, you can wipe the glass with a glass cleaner or either a damp cloth ( use a lukewarm water ) but dont actually put water on the glass. make sure you unplug the scanner from power source when cleaning it. If that doesnt help then it may need a servicer to have your scanner fix. If your product is still within the warranty call manufacturer for warranty claims.
Hope this helps..
  • Dell Master
  • 19,396 Answers
Open the cover and clean it from below with isopropyl alcohol
Posted on Apr 30, 2008
When I scan a photo, my Brookstone IConvert photo scanner has white lines all over the pictures.
The reason it has white lines is because the glass is dirty in the inside. If it has one speck of anything inside the scanner it turns into a line because it stays in that one place as the picture slides over it. So that line is actually a dot that is covering the picture throughout the scan. The solutions don't work. I don't suggest taking yours apart. I took mine apart and cleaned the glass. The pictures scanned fine and then the lines show up again. The real solution is to get your money back if you can. It will do this over and over. It's a design flaw in the scanner. The picture is actually squeezed as it it scanned. As pictures are squeezed against the glass... residue builds no matter how clean your pictures are.
Jul 30, 2010 | Office Equipment & Supplies
Pictures scan with a dark line
Hi ,
can you please specify your printer model for more appropriate solution Buddy!..Thank you!..
Jul 19, 2008 | HP Office Equipment & Supplies
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
HP Scanjet N6010 Once documents are scanned a line appears on the scanned copy
The lines on a scanned document are typicaly caused by dirt on the scanning glass. To clean it use the following steps.
1. Unplug unit.
2. Open the fron access door from the top.
3. Clean both top and bottom **** glass that run the width of the scanner.
The glass can be cleaned with a lint free cloth and a mild glass cleaner.
Jul 21, 2010 | HP Scanjet N6010 Photo Scanner
Why is it that when I scanned a picture or document that there is a line running through the scanned picture?
A line usually will run through your picture if your scanner has some dirt on the glass. Try the following: -
Take a soft clean clothe/tissue and ensure the glass where you place your document for scanning is dazzling clean. You may do this repeatedly as the mark might be very small.
This worked recently for the hp 3050 psc and fax machine and am sure might work for you.
Please let me know this help you.
Jun 25, 2010 | Computers & Internet
Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
Dell 962 Photo All-In-One InkJet Printer Logo
94 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
