Question about Dryers
Drying times are very long, there is heat , but sometimes there is a slightly burning smell in the drum dryer is a bosch logixx sp601/51
  • 78 Answers
If you are comfortable with taking your dryer apart, do it and clean out all the lint. make sure it is unplugged before you do. also while you are in there examine the heating coils for any damage. if they are broken or damaged, get new ones. it's usually cheaper to check around locally before going to the manufacturer. turn the electric breaker all the way off and then on when you are ready to try it out. it is imperitive to NOT use it again untill it is checked out.
Posted on Apr 29, 2008
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 03, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Logixx vented dryer not working correctly
I had the same problem.
I took of the cover on the back and found the heating element had blown. I just replaced it for a fraction of the cost of a new drier, just unscrewed it and conected the two wires easily.
Jan 25, 2009 | Bosch Logixx WFT 2806 Front Load...
Dryer heating but not drying the clothes
be 100% sure there is a good air flow outside the house where the dryer vents out this is the most comon problem. Next check in side the dryer drum at the back give a slight tug on the drum toward the front of the dryer you are looking to mack sure there is not a gap between the bulkhead and drum felt. If there is a good seal there then I would repace the Theremostat on the blower housing this is the cycle theremostat
Jan 19, 2009 | Whirlpool LER4634J Electric Dryer
Gas dryer with gas smell and no heat
It sounds like your GLOW BAR gas igniter is bad. This is an electric powered heater coil that , when it glows red hot, ignites the gas burner. This part normally fails at least once during a dryers normal service life. If you are handy, you may be able to replace the part yourself. Otherwise, have a technician look at it. If you want to DIY, go to an appliance parts store . Remove and observe the GLOW BAR from your gas dryer. If one of the metal element appears to be burned open,replacement is necessary.. Show the part, along with your dryer maker, model, and serial number, to the store employee. This person can give you helpful info along with a new part. If the GLOW BAR is NOT burned out, seek out a technician.
Aug 29, 2008 | Bosch Nexxt WTMC3521UC Gas Dryer
Bosh logixx
Click on your model number above (below FIXYA ) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Feb 24, 2008 | Bosch Logixx WFT 2806 Front Load...
Dryers Logo
204 people viewed this question
Top Dryers Experts
