Bush pdp42tv006 4amp fuse blown . not the main fuse.checked for shorts .any help? thanks
    Scholar:
  • 34 Answers
Ferny28,
This is a common problem on these plasma TV's. The problem resides in the high voltage boards known as the X and Y Sustain boards.. You can purchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
To test which board is failing, you need to check voltage input to the YSUS board first... Input should be 120V from Power supply, output should be above 250V.. Do this test with XSUS disconnected. IF 250+V exists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
Pls check the main power supply<regulator> hang the loads going to secondary supply,
Posted on Apr 29, 2008
AVR142 totally shutdown no lcd display no lights on volume control no sounds only main switch have a light,plz help me thanks a lot
Sounds like either a blown main power fuse or power transformer. If the fuse is blown it probably means a short in the amp somewhere. If it is the transformer, it can be replaced - but may cost more than the unit did.
Dec 26, 2012 | Harman Kardon Audio Players & Recorders
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
It's not running and no sign of humming
Your fan have a blown thermal fuse.
The cause of blown thermal fuse is overheating of the fan motor, due to lack of lubricant in the shaft bushing.
The thermal fuse is a safety precaution to prevent fire when you left it running and your away from home.
It is located at the back of the winding connection, accessing it, you have to disassemble the motor cage housing. If you have no experience on such repair better bring it to any electric tech shop to replace the said part and they would check also the bushing and will add a new lubrication to the shaft.
Hope that helps you out.
Thanks for asking FixYa!
Sep 15, 2011 | Dryers
After I put a fuse in the player, and plug into wall, the fuse immediately blows.
Your fuse blown again because you have a short on the circuit. You may visit my link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info.
I've suspect that you have short on rectifier diode/main filter capacitor/regulator IC/transistor. This is quite fixable.
Hope it may help you.
Thanks for using fixya.
JDVillanueva
Feb 03, 2011 | Samsung DVD-V3650 DVD Player/VCR
The mains input fuse (4amp) and a (1amp) fuse on the main power out board were blown. Replaced fuses and switched on, blown again, disconnected output from transformer to main board (4amp) fuse did not...
The cheapest option is to replace the transistors (a quick check on google will tell you how much they are). If they are common transistors you will be able to find them and get them quicker then searching for a board that could be no longer being made.
Sep 02, 2010 | Mackie SWA1501 Subwoofer
Panasonic ct 32hx42f blows main fuse
Blowing fuse points to high voltage transformer being short. Check the primary coil of the transformer first.
Dec 14, 2017 | Panasonic CT-32HX42 32" TV
Parking lights out
Check the Fuse Box inside for a Blown Fuse with a Really Good Flashlight. You will be able to see which one is Blown. Then Locate the Fuse Relay Box under the Hood and look at the Diagram inside the Cover and Locate the Illumination Relay, Replace this if you cannot Find a Blown Fuse. Please Rate My Response! Thanks!
Feb 06, 2009 | 2006 Scion xB
Hi, I Have a Warfedale pro BX1780sd unit, last night during a performance the mains fuse (8Amp) on the back of the pannel blown. I looked in saide today and found that both the 15 Amp fuses inside the...
check shorted rectifier diode in main power supply,check shorted power transistors,if it is power IC amplifier unsold it put fuse if doesn't blown up the problem is solve.
Sep 07, 2008 | Audio Players & Recorders
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Televison & Video Logo
396 people viewed this question
Top Televison & Video Experts
