1991 Toyota Tercel Logo
Anonymous Posted on Aug 11, 2010
Im a female unfamiliar with car repairs. Please help me understand where the thermostat is located in my daughters 1991 toyota tercel.
  • Anonymous Aug 11, 2010
    but WHERE do i find the thermostat to begin with?????
Duane Wong
Level 3:
  • Toyota Master 6,826 Answers
  • Posted on Aug 11, 2010
Duane Wong
Toyota Master
Level 3:
Answers
6826
Questions
6
Helped
2861904
Points
20234
REMOVAL & INSTALLATION The thermostat's purpose is to control the flow into the engine from the radiator. During warm up, the thermostat remains closed so that the coolant within the engine heats quickly and aids the warming up process. As the coolant temperature increases, the thermostat gradually opens, allowing a supply of lower temperature coolant (from the radiator) to enter the water pump and circulate through the engine. NOTE: A thermostat should never be removed as a countermeasure to overheating problems. This will only decrease the cooling system efficiency and add to the problem. The vehicle cooling system should be serviced with necessary components replaced.
  1. Drain the cooling system and save the coolant for reuse.
  2. Remove the water inlet housing (disconnect any electrical connections on the housing) and remove the thermostat. Carefully observe the positioning of the thermostat within the housing before removal.
  3. Install the new thermostat in the housing, making sure it is in correctly. It is possible to install it backwards. Additionally, make certain that the air bleed valve aligns with the protrusion on the water inlet housing. Failure to observe this placement can result in poor air bleeding and possible overheating.
  4. Install the water inlet housing cover with a new gasket. Install the two hold-down bolts and torque to 43 inch lbs. (4.9 Nm). Do not overtighten these bolts!
  5. Refill the cooling system with coolant.
  6. Start the engine. During the warm up period, observe the temperature gauge for normal behavior. Also during this period, check the water inlet housing area for any sign of leakage. Remember to check for leaks under both cold and hot conditions. Fig. 1: Always observe the positioning of the thermostat in the housing before removing it im a female unfamiliar with - 85993075.jpg
    Fig. 2: The thermostat should be installed with the jiggle valve upwards 85993076.gif
  • Duane Wong
    Duane Wong Aug 11, 2010
    One can follow the upper radiator hose, the thick black hose, to the engine. It's in that vicinity.
    Also, one can buy one from a parts store to see what it looks like.
    It's round and has a spring on it.
    There is a picture of it that you can open by clicking on one of the icons after the Figures.
  • Duane Wong
    The thermostat is not directly viewable by looking under the hood. One has to imagine where it is first, and look at how the part fits in the engine behind some metallic parts.
Were is the tps located at on 1996 toyota tercel
the throttle postion sensor is located on the throttle body on my camry ist behind it so im guessing ist behind the throttle body
The radiator fan will not come on. 1991 toyota tercel. just put in a new thermostat. checked the fuse.
If the fans are not coming on try replacing the coolant temperature switch and see if that gets it.
Where is thermostat on 1991 toyota tercel
under hood, drivers side, upper engine area,engine end of upper radiator hose, mounted in coolant outer housing
I need the electrical diagram for my toyota tercel 1991
Auto Parts stores carry Chilton's or Haynes repair manuals that usually have wiring diagrams in the back
Daughter's car, '95 tercel, called and said it cut off, got it crunk, termperature gauge went up to hot, pulled over, gave it a few minutes, drove a little further, then it shut off, it has anti-freeze in...
its probably a stuck thermostat.the vavle on it stayed shut built up pressure blew the top hose. cheap an easy ti fix. where the top hose is located n the engine is the thermostat housing undo both those bolts take out thermostat put in new one the same way the other came out a little permatex and the gasket bolt back down let sit.connect hose and refill anti freeze it should be good then
2helpful
Tips for replacing head gasket on 1991 Toyota Tercel
Very difficult. Make sure that the cam shafts are well marked for there positions.
1helpful
Where is the thermostat located on a 1990 toyota tercel 5dr hatch? 3E engine
follow top hose from radiator to engine thermostat is located in the housing the hose connects to engine
1991 toyota tercel brake lights work rear running lights dont
sounds like the wiring was repaired and someone tapped into the headlight circuit instead of the parking light circuit
I need directions on replacing a thermostat for a 1991 toyota tercel, that I can print out.
Go to autozone.com they have online how to for most vehicles.
Hope this helps!
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
