Question about MTX Chevrolet Camaro/Pontiac Firebird 1993-2002 Thunderform Loaded with 10 Inch Subwoofer and Amplified,... Car Speaker
Steering wheel audio controls (2001 camaro)
I want to change factory radio but do not have wire layouts to get right adapter
I can not find an adaptor for my radio to work with my steering wheel control. How can I hard wire the new radio to the existing SWC without the adaptor ?
mostly likely no, you will need an adapter to send the right signals from radio to steering wheel controls. there mostly universal adapters
Jul 09, 2016 | 2001 Dodge Ram Pickup 1500
What wire runs steering wheel controls on a 2500 gmc sierra
This is not a question for JVC but more for GMC. On the JVC radio side, if it can be controlled via steering wheel, you will see a blue with yellow stripe cable that states [STEERING WHEEL]. Not all radios can adapt to steering wheels controls.
Aug 02, 2014 | JVC AM FM CD DET FACE CAR STEREO
82 camaro z28 radio wiring
I hope you didn,t cut off your original factory radio harness, The easist way is to buy a wireing harness adapter kit.That hooks up to the wires on your new deck, End has plugs on it that plug into your factory radio harness. They can be braught at most places that sell end install car audio equipment for $15to $25 at the most.
Oct 21, 2012 | Pioneer MVH-P8200BT - Bluetooth/MP3/iPod...
What is aswc harness in the gmos-lan-02 harness
Axxess ASWC Steering wheel control
ASWC = Axxess Steering Wheel Control, it's the additional wire harness you need in case you have controls for your radio / sound system on the steering wheel.
Apr 10, 2012 | GM Carts Axxess Gmos-lan-02 Gm Factory...
Need to hook up a steering wheel control interface 2002 z28 camaro
Hello! Here is steering wheel print...NCA=No color Assigned...Yellow to fuse...Blue to Radio...
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
Guru...saailer
Jan 18, 2012 | PAC Audio Car Audio & Video
Can you put a newer radio in a 2001 yukon
Hi, my research indicates you can install a single din aftermarket head unit in the 2001 Yukon.
A couple of good websites to use are crutchfield and modifiedlife.
Crutchfields will identify exactly what adapters are needed, and modified life has the factory wire colors.
You will need an adapter to fill the space between the aftermarket stereo and the hole left by removing the factory head unit.
You will also need an antenna plug adapter.
I recommend you buy the wire harness pigtail to simplify the installation--this may or may not include the antenna plug adapter.
If you have onstar, you will need an additional adapter.
If you have steering wheel controls, you will need another adapter to keep those.
Keep the above things in mind when selecting a new aftermarket stereo, as you will need one that is compatible with steering wheel controls and onstar, if you have either of those and want them to continue to work with the new stereo.
Crutchfield has an link called "outfit my car" that takes you through a "Turbo tax" style questionaire and tells you what will work and what you will need. here is the link: http://www.crutchfield.com/App/Car/outfitmycar/MyCar.aspx
Assuming you have a base Yukon, here are your factory wire colors from modifiedlife.com:
2001 GMC Yukon Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Please let me know if you have questions, and thanks for using FixYa.
Jan 18, 2011 | 2001 GMC Yukon
What is the color code for the radio ? we are changing the radio and need the wire codeing for the factory radio
For 2001 Buick Century Car Radio Stereo Audio Wiring Diagram...
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Hope helps (remember to rate this answer).
Dec 30, 2010 | 2001 Buick Century
Cruise control,and radio controls on steering wheel, now air bag
The problem is the coiled ribbon contact under the steering wheel (we call it the clock-spring contact) that connects the stereing wheel controls to the steering column wiring harness, this is a printed circuit that is coiled to allow the wheel to move and still have a psychical contact for the wheel switch's and the airbag, anyway replace that contact coil, u must disarm the airbag to do this repair, follow the factory procedure to do this or serious injury can result if the airbag fires.
Jan 13, 2009 | 2001 Dodge Dakota
Steering wheel audio controls wires
those controls will only work with your factory audio unit not aftermarket ( it has an interphase )
Aug 12, 2008 | 2002 Nissan Maxima
Car Audio & Video Logo
46 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
