Question about Canon CanoScan LiDE 70 Flatbed Scanner
I have got a jamed scanner its loud and annoying
High my scanner is makeing wierd sounds and is not moving, i think its jamed. if any one could help me i would be thankfull
    Scholar:
  • 111 Answers
Move the lock switch back and forth and leave it in the unlocked position. The lock switch is located on the bottom of the scanner.
Posted on May 09, 2008
What can be done to fix my fi-6670?
You may need to lubricate the moving parts. I had a printer that was playing up like this and the bars that the print head moved on needed a tissue with a small quantity of machine oil to be rubbed on the bar to allow the print head to move freely. If all the scanners are the same age the lubrication they had may have worn off.
Apr 29, 2014 | Fujitsu Fi 6670 - Document Scanner -...
When plugged in via usb, the LIDE 600F scanner makes a high pitched buzzing noise and will not start up.
Hi
The scanner is not able to find the home position to start.
Hence open the scanner and check to make sure the scanner assy. is moving to the end and when it senses the home position it will try to move a little away from it and then return back. But if the sensor is dirty or broken it will make a loud noise like belt slipping.
Try to find the sensor on back of the Tube assy. and try to fix it.
Jul 23, 2011 | Canon CanoScan LiDE 600F Flatbed Scanner
When trying to scan, the scanner makes a loud clicking sound and the scanning carriage does not advance under the glass plate. It looks like the movement belt has come lose or detatched.
Hi There and Welcome to Fixya.
If the scanner's 'clicking' sound is louder than usual, plus there's issues with the scanning carriage, it is quite evident that this device requires repair/parts replacement. Please note that I'm highly recommending a certified or trained technician to do such job due to the intricacy of internal parts (not to mention the architecture) of the scanner.
For your convenience, I have included the support site for Lexmark for you to check on the repair options and more information surrounding the product :
Lexmark Support
I hope this helps and Thank you for using FixYa.
Apr 08, 2011 | Lexmark Office Equipment & Supplies
My scanner is making a loud cogwheel sound and then I get a message that it can't copy
Hi there
Check for the scanner lock of the printer and maybe it was accidentally push it.
I hope it helps you.
Feb 20, 2011 | Visioneer OneTouch 9120 Flatbed Scanner
Why is it making noise every time i turn on power
If the noise is a high pitched whirrrrr, it is the scanner warming up and getting ready for the scan job. If it clunks, or the noise "sounds bad", make sure the "Lock" is not engaged on the bottom of the scanner.
Apr 29, 2010 | Epson Perfection 3490 PHOTO Flatbed...
WANT TO DOWNLOAD A USER MANUAL FOR THE EPSON V500 SCANNER
Epson Perfection V500 installed. My computer recognizes it and diagnostic note says all okay. B ut when I turn on the power of the scanner, the grren light comes on in the front for about 15-20 seconds and then the scanner makes a loud grating noise and the green light turns orange and keeps flashing. No scan is attempted. TGhe noise sounds like something that should be moving can get started -- but nothing moves when you look at it. Should I take it back where I bought it?
Dec 24, 2009 | Epson Perfection V500 Flatbed Scanner
My scanner makes a loud noise on start up what is it ?
It is normal for your Epson scanner to produce noise on startup as it calibrates the motor that moves the scan mechanism when powered on. But if this is too loud than normal, it means that there may be already a problem with the motor and must be replaced if it wouldn't give out quality scans. Otherwise, it is working normally.
Nov 06, 2009 | Epson Perfection 1660 Photo Flatbed...
Paper james during scan,clicking sound in upper
Clicking sound is not a healthy sound, check if any gear wheel is damaged. Is the tray moving up properly? There are a few sensitive parts like the clutch, gears etc. If you cant fix it please call a trained technician, so that damage is minimal.
S. Mohan
Nov 04, 2009 | Canon CanoScan DR3020 Path-Through Scanner
Epson perfection 2400 photo scanner stuck with flashing red light
You may have accidently pushed the LOCK button - this button is used to LOCK the carriage into place when moving the scanner to another location or shipping it.
Check for a button and the picture of a LOCK, it is usually at the back of the scanner, you can push it left or right, and you have an open lock and a closed lock picture under it. Make sure you didn't accidently push it to the LOCK position when holding the scanner - that loud sound means your carriage is locked and cannot move - once you set the button to UNLOCK this should solve your problem.
Jul 27, 2009 | Epson Perfection 2400 Photo Flatbed...
Epson Perfection 4180 croaking
This is a good fairly high spec unit so I am sorry to say that I think you need to get it to a repairer for a quote for repairs and then to decide if it is cost effective to repair or simply replace the unit. Is it still under Warranty?
Good luck.
Apr 11, 2008 | Office Equipment & Supplies
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
143 people viewed this question
old marine
old marine
