GE AJCQ08ACB Air Conditioner Logo
Posted on Aug 11, 2010
I had a power outage and my GE 10000BTU window a/c unit stopped working after 4 weeks. When the power was restored the unit wouldn't come on.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
232
Points
I bet that your ac was running on low voltage for awhile before the black out and the compressor burnt out and or seized. indication . A hum and a click indicates a bad compressor
W10338685B Kenmore toploading HE low-water washer. Stops working at rinse/spin cycle. What's the fix?
Hello. There are several things that can cause this problem. The first thing I check is the drain pump--if there is 120 volts getting to the pump, and the pump is not running, the drain pump is either jammed or the motor is bad. If there is NOT 120 volts at the pump when it should be running, that indicates either a broken wire from the main control board or, a defective main control board. If the unit senses water in the tub, IT WON'T SPIN. One of the other causes of a no-spin could be a defective lid lock or even a corrupted/damaged main control board. The drive motor for the unit is controlled by the main control board which is told what to do by a program. If you have power outages, the board could have been partially damaged by a current surge when the power was restored. (Outages are NOTORIOUS for damaging circuit boards in appliances). If it wasn't blown out immediately, USUALLY about 4-6 weeks after the event the chips on the boards start to fail causing varied problems.
My sister year old GE dishwasher won’t start. Ha don’t a power outage and after power came on she tried to start it and wouldn’t work.
If it was running when the power outage happened, that may have "fried" the control panel.
She needs to have it checked by an appliance repair person to see if that is so.
God bless your efforts.
My ge oven stopped working after power surged code coming up on front panel: LCDBoard 'T_PP_Profile_V_3_35' Main relay V3.2, Aux Relay V3.2 EEPROM PARAMETER PAGE CRC 15 OEBC Initalization in progress
How to repair an oven: resetting the power - YouTube
? 3:13
https://www.youtube.com/watch?v=HenawxpSYow
Feb 14, 2011 - Uploaded by VideoJoeKnows
How to repair an oven: resetting the power might be the only thing you have to do....can you imagine? "You mean it ... My ovendoesn't work: what do I do now? ... How to Fix an F1 Error On a Kenmore or GE Range - Duration: 11:41. ... Oven Repair-Not heating after self clean-Kitchenaid,Whirlpool,Maytag ...
GE Oven quit working, after power outage - DoItYourself.com ...
www.doityourself.com/.../363632-ge-oven-quit-working-after-power-ou...
Oct 14, 2008 - Hi, our GE Glass Top Stove/Oven stopped working after a power outage ... My guess: the circuit board on the oven (behind the digital display) ...
Dec 29, 2015 • GE Ovens
1helpful
How do I reset the control panel? Other ideas?
Hello. If your unit is running continuously, the timer/control board is defective and needs to be replaced. I need the make/model number to help you accurately. If you have the mechanical timer(round knob that turns), it's not advancing(no repair possible). If the unit has an electronic control, the program quite possibly is corrupted--or a relay is stuck causing the problem. Have you had a power outage recently--3-4 weeks ago? These are notorious for damaging the control boards from the current surge when power is restored. I hope I helped you--definitely give me the model number, thanks!
Oct 17, 2015 • Dishwashers
Control panel is not responding
Most likely, if power *is getting to the unit*, (there are lights lit on the washer), then the culprit will be a shorted user interface board(control panel). This is a fairly common type of issue with dishwashers. The soft-touch buttons or the touch panel has a shorted button or area(depending on the type you have) and nothing else will function because the unit thinks you're still pressing a control button. Also, a VERY common cause of this issue, aside from moisture or bugs, is a power outage damaging the console when power is restored due to a surge. After an outage where damage occurs, the symptoms don't usually start for about 3-4 weeks after due to damaged chips on the board starting to fail.
Aug 20, 2015 • Dishwashers
Hi! After a power outage my Little Giant SPBS-12 backup system sounded an alarm that wouldn't quit even after power was restored (it was only off for an hour). When unplugged the louder and more...
What is the age of the unit? Those batteries don't last forever and are constantly under a small charge. When the outage happened the battery discharged and the sensing circuit was able to tell that the battery was no longer any good.
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
