Need new black cartridge don't know how to change cartridge
  • 1 more comment
  • Beck1e Apr 29, 2008
    HP K550
    Thanks
  • Anonymous May 30, 2008
    have no idea how to remove cartridge
  • DHANANJOY ROY May 11, 2010
    which printer are you using give the details
  • 54 Answers
Http://h10032.www1.hp.com/ctg/Manual/c00501032.pdf
this will help you to change the cartridges
Posted on Apr 29, 2008
How do i change the cartridge ?
901 is the cartridge what is the printer model?
Jan 31, 2015 | HP Two 901 Black ink cartridges
I need to print a lot of only black and white documents, I have full cartridges of black ink but the color is empty. For some reason it keeps printing the black off the color cartridge. I need to find out...
Since I don't know what operating system you have on your computer, here are the steps for all Windows operating system from Canon for your printer. If these don't work, let me know but usually once you change the settings for black and white only, it works fine.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#ServiceAndSupport
Apr 16, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon IP4300 - the two black ink cartridges
No!
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Don
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Says Black ink supply expired. Installed new
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 10, 2009 | HP OfficeJet 7140xi All-In-One InkJet...
Black wont print. Changed to new cartridge, nothing
Don
Nov 19, 2009 | Office Equipment & Supplies
I have changed the black cartridge twice but a
Don
Oct 22, 2009 | HP OfficeJet d145 InkJet Printer
Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
Jan 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Installing a new ink cartridge
After working with the copier for over an hour, my husbband discovered quite by accident where the ink cartridge was located. It is inside on the left hand side, above the try that holds paper, and is next to impossible to see. It pulls out to the middle of the tray, and the cartridge can then be changed. Thank you so much for you time.
Sincerely,
Becky LaCour
Mar 03, 2008 | HP OfficeJet D135 All-In-One InkJet...
Black will not print
Hi springfield, From what you describe I don?t think it has anything to do with your printer drivers. I would try the following: -Run a couple of nozzle cleaning jobs. -If no change I would suspect a defective cartridge and would try a brand new HP cartridge. If these don?t work I?ll need some more details such as do you refill cartridges, buy remanufactured cartridges or use new HP. Also is this still under manufacturer?s warranty? I don?t want to suggest anything that would void it. Let us know what happens and please don?t forget to rate the posting.
Jan 23, 2007 | HP LaserJet 3300mfp All-In-One Printer
Brand New Printer
Hi Teetle, No, it not normal to only get two pages per cartridge. I would try the following before contacting Epson tech support: -Remove the cartridges and clean the contacts on both the printer and cartridge. -Reinsert each cartridge making sure it is seated correctly. -Buy one black cartridge and install. It is possible that the cartridge is defective but since the magenta cartridge is showing low its unlikely. Tech support will want you to try it before they will replace the printer so you?re best off trying it now. If after trying this steps there is no change and if you?ve had it for less than 7 days I would talk to your retail store. Usually they will just trade your defective unit for one in stock. If you have had it longer contact Epson support and explain what it happening and what you?ve done. Make sure you mention you?ve bought a new Epson black cartridge with no change. Let us know if you have any other questions and please don?t forget to rate this post.
Jan 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
80 people viewed this question
jasbo
jasbo
