Question about Zanussi ZWF1430W Front Load Washer
Machine filling and then immediately draining
I have ZWF1430W problem, whichever programme I put it on, it fills with water through the prewash (despite showing it being on the wash part of the cycle) and then immediately drains out again i.e. it will not wash anything. If I manually move the machine through the cycle it will spin and then drain. As per the manual I have checked the drain pipe and there is no probs with this.
  • 4 Answers
Hi You need to higher your outlet pipe on the back of the machine there is usually a clip to hold the pipe in place 3/4 of the way up the machine so it looks like a u upside down its should stop the machine from emptying straight away
Posted on Jul 08, 2008
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Zanussi 6hg 1400 rpm won't drain
My machine won't fill up with water and I noticed it started flashing e21 and its not spinning very well either what could the fault be
Aug 17, 2012 | Zanussi ZWF1430W Front Load Washer
It dos not stop filling up water
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 27, 2012 | Zanussi ZWF1430W Front Load Washer
Prewash drains into washer before starting washer
Check the tray before you fill the powder. There should not be any water. Once you switch it will drain along the water when water is showered inside the tray.
Apr 01, 2010 | Samsung WF448AA Washer
Prewash
i removed th presure chamber and noticed there was a blockage i pu a thin screw driver through this and placed back the pressure chamber and my machine has worked as normal no problems.
Dec 25, 2009 | Hotpoint WMA32 Front Load Washer
When start washing, filling water comes out from
This is most likely due to having the height of the drain hose too low in the drain pipe so the water siphons out as the machine tries to fill up. This will eventually lead to an F20 error displaying saying that the machine was not able to fill with enough water in the 6 minutes allowed by the on board controller in the Whirlpool.
The solution is to measure the height of the top of the arch of the drain hose or direct connecting point to a drain and make sure that his is at least 32 inches and no mort than 36 inches from the floor.
Oct 11, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
I have a hobart dishmachine model# CRS-66AW after filling dishmachine water will not stay in the wash tank, sometimes half of the water drains out. we have replaced the o-rings on the drain plug recently....
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
Mar 07, 2008 | Dishwashers
Zanussi ZWF1430W Front Load Washer Logo
171 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
