Question about Panasonic TH-50PX60U 50 in. Plasma HDTV
Color change-blue people
All of a sudden my tv color change and all the people are blue. What can I do to fix this?
If you have cable or dish box check your HDMI rgb cables on set and digital box
Posted on May 17, 2008
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
How to get blue background in color tv?
This could be a defect in the degausing circuit, but to confirm, please supply the make and model and a mre detailed description of the colors on the screen. You can try unplugging the set for 10 minutes and then turn on the set. That may reset the circuit enough to confirm the problem. Please update this with the results of that experiment and we'll continue from there.
Thanks,
Dan
Jul 25, 2009 | Televison & Video
My tv experienced a sudden color shift with the blue moving to the left
Blue color moved to left because of failure of convergence out IC in TV
that need to be replaced. Call local TV repair shop to fix it.
Jul 13, 2009 | Sony KP-57WS500 57" Rear Projection...
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
May 21, 2009 | LG 37LP1D 37 in. LCD Television
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Nov 20, 2008 | LG 32LB9D TV
Akai LCT2701TD
Unplug your TV for a while and see fi you are getting the same issues after you plug it in. If it works after, then you have an overheating issue with the power supply or main board.
Let me know if you need further assistance.
Oct 30, 2008 | Akai LCT2701TD Television
TV colors distorted
make a degosing coil or try to look for a website how to make it in the phillipine we only make it coz we can't buy or its not available in the marker ok thanks that is the only solution you can do k
about akai tv may be it just coldsolder in crt socket try to solder it thanks inform me
Sep 10, 2008 | Televison & Video
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Panasonic TH-50PX60U 50 in. Plasma HDTV Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
