Question about HP Color LaserJet 2600n Printer
Marks on documents
Ii am able to wipe the marks from the teflon sheet but they reapear when printing takes place
  • Aziz Chaudhry May 11, 2010
    Do you mean the roller?
I have the same problem, anyone has an answer? Even after the cleaning mode the marks reapear!
Posted on May 15, 2008
Why does adf cause line in center of printed documents?
Does this happen when when you place a document on the big glass? when you use the doc feeder you are using the small slit glass clean the slit glass if the problem goes away when using the big glass or when you print, then you know the bottom part of the machine is doing ok and its the scanner section which is the big glass area and the slit glass. you may have to to look at the glass at different angles to see the mark.
Jan 21, 2016 | Epson WorkForce WF-3620 Wireless Color...
After printing first page second page printing becomes jammed every time and then I have to free jam manually
I get this problem sometimes. The quick answer is to put a large 'bulldog clip' around the stack of paper, and feed in one sheet by hand. When the sheet is almost printed feed in the next sheet.
The long term solution often is to service the 'rubber' paper feeds that get covered in dust. Use a damp cloth and press against one roller at a time, rotating a bit at a time. Not as easy as it sounds!
Then use a bit of fine 'sand' paper to remove the shiny surface on the roller(s) and wipe clean again.
Oct 10, 2015 | Canon LBP2900
Printouts have marks on right side of paper
1. Check with another cartridge.
2. Replace teflon sleeve if its available or replace fuser assembly.
Nov 29, 2012 | HP LaserJet 2420 Printer
How to print a document more than 1 page long
If you are using single sheets you have to load one sheet at a time. Send doc to printer and load sheets one by one. Printer beeps 3 times calling for the next sheet.
Oct 03, 2011 | Epson LX-300+ II Matrix Printer
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
What is E7 on the canon mp160, and not working anyway..
When the head alignment sheet was not filled in properly Printer show E7.
  • Confirm circles on head alignment sheet are filled in properly MP160
Head Alignment Sheet The head alignment sheet was not filled in properly.Confirm the circles were filled in as follows:
Good example:
Bad examples:
If more than one circle is filled in, reprint the Head Alignment Sheet.
Print Head Alignment
  1. Ensure that the printer is powered on and open the paper output tray. (Confirm that the paper thickness lever is set to the left.)
  2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder (or ASF).
  3. Press the <Maintenance> button several times until [P] is displayed in the LED.
  4. Press the <Black> or <Color> button. The machine prints the head alignment sheet.
  5. From each group, select the pattern which has the least visible streak.
    Example of the pattern with the least visible vertical streak
    Example of the pattern with the most visible vertical streak
  6. Pencil in the circles on the left side of the selected pattern, using a dark pencil.
    < 1 > Good example
    < 2 > Bad example: Checkmark
    < 3 > Bad example: Line only
    < 4 > Bad example: Not dark enough
  7. Open the document cover and load the head alignment sheet on the platen glass.
    Note: - Place the printed side down.- Align the sheet with the alignment mark (shown by the arrow) on the lower right corner of the platen glass.
    05sj00115_06.gif Alignment Mark
  8. Close the document cover gently.
  9. Confirm that U is displayed in the LED.
    If U is not displayed, press the <Maintenance> button several times until [U] is displayed in the LED.
  10. Press the Black or Color button.
  11. The machine scans the head alignment sheet and aligns the print head automatically.
Feb 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Which part does teflon sheet sits in HP laserjet printers
If you are trying to print on 'teflon' sheets - then use tray 1. And make sure that you set the driver to TEFLON, the driver in the application, that is.
Dec 07, 2009 | HP LaserJet 3015 All-In-One Printer
White vertical line on pages from brother mfc-7420 printer
Do a half print test......send a print job to the printer listen to the printer...as soon as you think the printer has printed a bit of doc inside the printer..not reaching the fusser ......turn off the printer
Remove the cartridge.....and watch the print inside on the paper can you see the marks.....if so than its your cartridge that is marking your print....
remove the paper by slowly pulling it be careful not to tear it
If the print hadn't been marked on half test.....remove the fusser unit and examine the Teflon cover for marks....try to remove stains off if there is.....avoid marking the Teflon as this will mark more on the print
do advise if this worked if not than you have some more options
Cheers!
Nov 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
70 people viewed this question
Seeker5211
Seeker5211
