Question about Mitsubishi VS-60805 60" Rear Projection Television
Colors properly aligned in HD but non-HD, or vice versa
I recently purchased a used Mitsubishi VS-60805 and set it up with brand new HD TiVo and Time Warner Cable. The picture was perfect on non-HD channels, but in HD I could see a vertically displaced red ghost image and a laterally displaced blue ghost image. I played around with the settings on the TV and found a video manual alignment feature that allowed me to line up a blue cross and a red cross, which made a white cross.
Now HD looks perfect, but non-HD has a vertically displaced red ghost and a laterally displaced blue ghost! Anyone have an idea how to make the alignment correct on both HD and non-HD channels?
  • 121 Answers
You have to make the alignment for all 3 formats....standard....1080i...and 480i
Posted on Apr 29, 2008
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
All colors are out of alignment. It is fine but after watching it for about 20 min. It will fall out of alignment
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 05, 2009 | Mitsubishi VS-60805 60" Rear Projection...
I have a VS 60805 and i need a Convergence Generator. They say these are no longer Available. Any Suggestions?
General Consensus is that Mitsubishi is a Piece of ****, has been for a long time and I was lucky that my Set worked as long as it did. I guess it is just another benefit of not have any national product in the US anymore. No matter I will never Buy Mitsubishi Again.
Jun 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS60805 screen
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Jun 16, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Where can I get good E2PROM settings for Mitsubishi VS-60805?
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Jan 30, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Fullscreen HD?
check to see if the box has a tv type setting in it's menu since I don't know what the model of the HD box is it must be in the user manual on how to set this up. it is not the tv that is the problem.
Jun 06, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Trying to get Fullscreen HD.
MY TV HAS SOUND BUT NO BIG PICTURE IT HAS A LIL PIC IN THE RIGHT HAND CORNER WHEN U PRESS MENU.
I HAVE MODEL NUMBER VS-50603
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
