Question about Acer Aspire 5580 Notebook
Battery Can anyone tell me what battery is in this laptop as my friend is having a problem with battery life and would like to know if it is possible to replace it will a longer lasting battery, tks.
    Problem Solver:
  • 8 Answers
This is the part number for the original battery
BATEFL50L6C48
unfortunately there is no extended battery to my knowledge for this model.
T0X1K66O
Owner, Founder, Head Technician
Leading Edge Computers LLC
87supra2jz@gmail.com
Posted on Apr 29, 2008
ASPIRE 4530 laptop. It is 11 months old. Battery life is 20mins
http://shop.ebay.com/i.html?_nkw=ASPIRE+4530+battery+&_cqr=true&_nkwusc=ASPIRE+4530+batterry&_rdc=1
Apr 19, 2010 | Acer Aspire 4530-5889 Notebook PC
My Dell 1525 has had ongoing problems in that it wont charge. Runs fine with the cable attached but no charging. Tried charger from another Dell with same problem. When looking in bios comes up with...
Try the battery from the other Dell system. If it charges fine, then its a problem with the battery, go for a replacement. Else, try updating the BIOS once from http://ftp.us.dell.com/bios/1525_A17.EXE. If it still doesn't charge the battery, then you may have to go for a motherboard replacement. If the system is under warranty then call Dell Tech Support @ 1-800-624-9896.
Good Luck!
-Abhishek
Apr 05, 2010 | Dell POWER SUPPLY Power Supply
Samsung S8003 Jet battery life problem
try to do these steps for your battery. 1.  switch off your phone 2.  check if the battery is loose or not properly fitted up.. >> insert a clean soft cloth at the back of your battery to make it more in tack or to fit more and observe. 3.  try borrowing the same fully charged battery from a friend and observe it.  >>if the battery gives you the same issue, you would want to give it a try at samsung service centers.  4.  ask the help of a friend who knows how to take a reading from your charger.  >>this will help you to know that your charger is giving the much needed voltage rating for your phone during charging.  >>you would also want to consider borrowing a charger from a friend and observe.  5.  consider bringing a additional fully charged battery while you are on the move or during your business trips.
for your notes, 1.  notes are really 100 characters, i am afraid,there is no possibility as of this moment to increase that.
Mar 07, 2010 | Cell Phones
Battery does not charge
Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
Most likely though, the replacement battery is bad.
Sep 02, 2009 | HP Compaq Evo n610c Notebook
My battery on lm70 express laptop only charges to 70%.fitted new but same problem.charged in another comp.and charged fine.
How do you know that it has charged to 70% and it is the correct percentage on your Laptop?May be you need some other program that are available on the internet that will tell you the exact charge percentage. Make note that In many ways, lithium-ion is superior to nickel and lead-based chemistries and the applications for lithium-ion batteries are growing as a result. Short battery life in a laptop is mainly cause by heat rather than charge / discharge patterns.Removing the battery from the laptop when running on fixed power protects the battery from heat. Make sure the AC Adapter that you are using [on both laptops] is supplying the correct voltage and if possible check with Load.
Jul 08, 2009 | Computers & Internet
Harddisk Security Code - Acer Aspire 5720
Generally you can remove passwords by removing something called the CMOS battery. This battery retains the configuration of the computer when the AC power and main battery aren't present or working.
The battery is generally located in the RAM expansion bay. Locate the battery and remove it. let the laptop sit without ANY power connections for at least 30 minutes. When 30 minutes or more has passed, replace the battery and connect power. Boot the laptop and press F2 to enter the BIOS setup. Generally no configuration is necessary on laptops so just save and exit.
May 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Battery life
Hi, Yes, there are both possibilities - either the camera is faulty and drains too much power from battery or the charger is faulty and can't charge the battery enough. How long does it take to "charge" the battery - from the moment you put the battery into charger to the moment it will signalize battery full? Do you have any friend with the same or similar camera? Try using your battery in his camera or recharging your battery using his charger. If not, try your local store if they will allow you to charge the battery in new charger... BTW it is normal for these batteries to have significantly lower life in very cold temperatures. The advise is to have the camera (or just battery) near your body so that it is not in cold for all the time and put it out only for time you take photo.
Jul 27, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Acer 3002 laptop battery life
What make is your machine? Try to buy an extended battery pack which can last almost twice the normal battery attached. Also buy a battery certified by your Computer Manufacturer only. A Chinese make or a locally made battery will only damage your machine.
Apr 09, 2007 | Acer Aspire 3002LCi Notebook
Acer Aspire 5580 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
