Question about Microsoft Windows Server Standard 2003 for PC
Server how server in printer install
  • Anonymous Apr 29, 2008
    then restart printer
  • 160 Answers
For solving the problem do the following:
1. Connect the Printer to the server where you want to install
2. Connect the power cable and switch on it.
3. Install the drivers of that printer
4. Restart the system
Let me Know that you problem is solved and rate me as Fixya!
Posted on Apr 29, 2008
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
Check that you do not have a firewall working. Set the printer by inputting the Ip or printer name when installing, do not browse for printer.
Aug 21, 2008 | Konica Minolta magicolor 2490MF Laser...
WPS54G Printer Server Setup
I bought a Linksys Wireless-G WPS54G printer server and trie to put it in my home network. Following the instruction from the manufacturer and spent many hours, I still couldn't make the printer server work. There was no problem to get the IP address from my DHCP server using the wired connection. But when I pulled off the network cable and tried the wireless connection, I got "connection failed" error at the last step to install the printer server. I checked my router's client monitor and found the printer server did get the dynamic IP address wirelessly. When I pinged that IP address, there was no response at all from the printer server. In another word, the printer server couldn't communicate with other devices in wireless mode in the network. I searched the Internet and found there were many users had same problem and couldn't resolve the issue even from the manufacturer technical support. As a last resort before I was going to send back the printer server, I switched the network router to one of a different brand. My previous router was manufactured by BUFALLO INC and the new one was made by D-Link. After I rerun the installation following the instruction, the "connection failed" error was gone. The printer server could work finally.
The tip here is: Try a different brand router when there is a connection failure problem for installing the WPS54G printer server, if possible.
on Mar 02, 2008 | Linksys Wireless-G WPS54G Print Server
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
Bought a printer server called Networking USB LPR Print server. It`s softwear does not support OKI but the install wizzard asks for installation disk from OKI. When I start the OKI driver installation...
  1. log into router
  2. look at the leases issued by the dhcp server in the router
  3. note the ip address assigned to the printer
  4. change the lease to be permanently leased to the printer server
  5. the print server will have a device name . you should be able to figure out which ip address is assigned / leased to it .
  6. You never assign a print server , or server or printer with a temporary dhcp ip address ! hence why you should change the lease of it to permanent .
  7. Then it will be assigned the same ip address by the dhcp server .
Mar 18, 2017 | OKI Computers & Internet
12 HPLJ 4300dtn printers suddenly started printing in booklet mod
Roger, did you try to re-install the driver? Are you running a 64 bit server? There have been several strange problems associated with 64 bit servers.
May 12, 2010 | HP LaserJet 4300dtn Printer
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link:
Nov 13, 2007 | IOGear GPSU21 Print Server
Printing from Server applications
Is this printer set up as the default?
right click on the printer
go to properties
set as default
Sep 10, 2007 | Lexmark T642 Laser Printer
Printing from 2 different pc, drivers installed on the server, get different quality
I think that quality settings is different for each user. If your printer have network card, pleas install printer with TCP/IP port in every PC, not from server, more job, but less problems.
Sep 15, 2006 | Konica Minolta magicolor 5430 DL Laser...
Microsoft Windows Server Standard 2003 for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
