No ordinary tv channels can only get Austar - Televison & Video
A TV electrician told me how. We had inadvertantly put the "demo" on and once we turned it off, it went.
Posted on May 07, 2008
My t.v. has no sound. It is a TCL led tv model no. L39B2610 Sound can be restored via the speakers of a small portable DVD player. But only for Austar channels
I would try a new main board, or check to be sure you have all the voltages coming from the power board, some sets have a separate voltage supply for the sound
Nov 20, 2017 | Televison & Video
How do I connect tv to Austar box
Hi Anonymous, Connect your austar to your television AV the turn the television channel to AV.............CHEERS..
May 07, 2016 | LG 50pt250 50" Multisystem Plasma Tv For...
Can only get the fox / Austar channels & can't find the normal free to air channels
the source needs to be set to antenna or AIR then scan for channels.
Feb 24, 2016 | Televison & Video
Hi.how do i get local tv channels when we go into it it gooes to austar how do i get local channels . i have runned the wizard and the local channels came up just not sure how to access them?
get the on screen menu on the screen scroll around until you find auto tuning
click on that and sit back as it finds all channels that are available in your broadcast area
go ok and exit
Sep 13, 2015 | Televison & Video
I have a Sony STR-K750 receiver running with a Samsung 50 inch series 6 tv.There is a digital lead running from the Austar receiver to the Sony receiver for sound.I have a Hdmi lead running from the Austar...
Run both audio and video to the tv, then use the tv optical audio out to go back to the receiver. The problem is, when you split the signal, the tv takes longer to decode the hdmi signal =, thus delaying it from the original audio signal.
Aug 06, 2013 | Sony STR-K750P A/V Receiver
How to connect austar and a blue ray DVD player to tv
your connection is wrong. Get a RCA wire. Yellow is video and white & red are audio.
Connect the wires to Output from the DVD. Video out and audio out. All that will be connected to the DVD will be output. The DVD is feeding out to the TV, so it is giving.
Now the all connections to the TV will be input. Because the TV is receiving from the DVD. Connect from the DVD to TV respectively.
Turn on the TV and DVD, then press Souce/AV on the TV. Now you should see a display and hear sound from the DVD through the TV.
I hope the above is clear. If not, please let me know.
Good luck.
Jan 04, 2012 | Televison & Video
The screen has gone blue with what appears to be a red padlock in the top left hand corner of the screen. I was a lone and had not touched anything that coul have casued this althought I was operating the...
So did you lock out the AUSTAR unit or the Projection TV. Have you tried a different source on the TV, such as a VHS player or a DVD player?
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Pay tv reception
Austar recently made changes that prevent the use of their smart cards in decoders other than Austar boxes.
Assuming you are using a legit Austar smart card, you will need to use it in the Austar decoder it was supplied with, for it to work now.
Apr 25, 2008 | Humax DRT800
Not enough av ports on t.v to connect dvd player and austar
may need to go to an DIY electronic store and get adaptore extenion boards
LG Support Search Results LG AU
Apr 10, 2017 | LG Televison & Video
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
