Model NW-892, machine beeps and displays E9 sign
Hi ,
The error relates to a problem with the water level sensor.
I was lucky to have 2 machines , 1 working and 1 with E9. I swapped the 'faulty' sensor assembly with a working one and guess what......E9 still showed. This was after I trimmed all vacuum lines by about 10mm and re fitted them. So it was not an air leak. I put the 'faulty' unit in the working machine and it worked fine with no error.
I tested the volage on the back of the connector and the 5volt was present.....weird I thought and a shudder or computer board replacement cost went through me.
After checking the connector to the sensor ( 3 pin molex type plastic ) I noticed the bottom brown wire spring loaded pin to be 'loose', which turned out to be broken away. Upon trimming the brown cable some corrosion showed but only at that one pin. So I guess some kind of poor connection, electrolosis, vibration problem ate away the metal of the springloaded prong.
Ideally replace connector with new and trim cable back about 30mm. Or solder direct onto the sensor with a low heat soldering iron and insulate with water proof heatshrink. .
Information supplied as a guide only and to be used at own risk.
To get to the sensor, remove lid ( pull away plastic pin at rhs hinge then lift away), unscrew 2 screws at the back of machine holding in the cover with the hot and cold inputs ( pull up from back and pry the front forward and up, as it is clipped in ) the sensor is at the lhs back.
good luck
Posted on Feb 15, 2009
E9 DISPLAYED IN WASHING MACHINE DAEOO MODEL DWF320LR WHAT IS THE PROBLEM
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
Jun 01, 2017 | Washing Machines
Will not sew making noise, have cleaned and checked bobbin holder displays E9 I also cleaned feed dogs
Difficult to say since we don't know the make & model.
Usually, you can search the internet for:
Make + Model + error code E9
and sometimes it will tell you what the error means.
Aug 21, 2016 | Sewing Machines
My NEC Millennium 892 is displaying E9 and sounding alarm when I start operation. Can you tell me what this means pls. Adam Pinner
You can read up on it, its a pressure sensor,, check the connection around pressure sensor or replace it, if you can't call a repair man.
Jul 09, 2015 | Washing Machines
How do I get rid of error message E9
e9 I believe is no clerk signed on with a Sharp register. If you have a sharp register just press 1 then "sign in" If not a sharp please repost with the model #
Oct 13, 2014 | Retail Supplies
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Aug 01, 2009 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
