Question about Bosch Dishwashers
Bosch Dishwasher 8502. Disconnected and laid up for six months. Now reconnected but 'check water' light comes on. Have removed filter in tap end of hose and checked for no kinks. Plenty of water pressure at entry point of hose to machine. Ant thoughts?
SOURCE: bosch shv55mo3gb
use this link then click on insruction manual download type in the model number remember 0 is a number.I know that sounds condesending but i forgot. I used the manual with the ending aus.
http://www.bshappliancecare.com/Bosch/Bosch_dishwasher_manual.html
Posted on Jul 01, 2008
  • 39 Answers
SOURCE: water not coming in
Hi jane_taylor4
The water valve could be bad. Depending on how old the dish washer is there was some prolems with the older water valves. the water vavle is the most common problem with the bosch dishwashers when water will not come in.
Posted on Sep 21, 2008
  • 409 Answers
SOURCE: bosch classicxx dishwasher not working check water light on
he there,
sounds like there may be something caught in the drain pump itself.
can you provide me with the complete model # on your dishwasher please?
thanks
Posted on Sep 25, 2008
skrbin
  • 121 Answers
SOURCE: Bosch S9GT1B not taking water
check electro valve,water-level switch.
Posted on Feb 15, 2009
  • 27 Answers
SOURCE: i have a bosch dishwasher classixx its less than a
if its less than a year old why dont you contact the manufacturers service team it will still be under guarantee as the bosch guarantee is 24 months
you can dowload a copy of the instruction maual free of charge from the bosch or bsh home appliances web site
Posted on Mar 12, 2009
DISHWASHER WON'T DRAIN ANLY HAD IT FOR 6 MONTHS. CLEANED FILTER. DID NOT HELP. WHAT TO DO?
Hi, if its still under warranty you should call bosch and get them to arrange a service engineer to come out and check it for a fault.
Jan 15, 2016 | Bosch Dishwashers
Bosch she43f15uc just stopped pumping water. Any ideas? it is only 18 months old.
My Bosch dishwasher had the same problem. After checking the over flow pan I removed the inlet hose to check water flow. There was none. I checked my cut off valve...open...I had water at the kitchen facet...scratch my head...I looked closer at the Bosch supplied braided water hose. It is directional (label indicating which end to hook to supply)....closer inspection reveals maybe there is a back flow valve in that side of the braided hose. Disconnect, blow air through...air passes freely...reconnect and bingo water flow at the dishwasher. In line back flow valve...can you imagine what a repair man would have charged for that?
Apr 04, 2012 | Dishwashers
Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
Mar 04, 2010 | Bosch Washing Machines
I have a bosch dishwasher classixx its less than a year old, the 'check water' light comes on and it doesn't complete the cycle. Water is left in the bottom unable to drain away. I have checked pipes as...
Feb 21, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch classicxx dishwasher not working check water light on
he there,
thanks
Sep 25, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher
Hi, it sounds like there is no watewr supply to the machine. Try turning the valve closed, and then opening it again. If that doesn't work, turn off the water and disconnect the supply hose. Then, with a bucket handy, turn the water back on slightly to see if water is coming through the end of the hose to the machine. Also check the gauze inlet filter for blockage with grit.
Let me know how you get on before rating the solution!
Thanks, D.
Jul 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shv55mo3gb
Mar 22, 2008 | Bosch 24 in. SHV55M03GB Built-In...
Dishwashers Logo
56 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
