Got a sound card fitted and now the front color(green and pink)are Not working
  • 62 Answers
When you installed the new sound card it disables the front connections due to them being set to run off the original sound card. What kind of computer are you refering to here? Also what kind of sound card was originaly in it? And what kind of sound card did you install. This information will greatly help with being able to get your front connections up and running again.
Posted on Apr 29, 2008
I have an 89 ford bronco and want to install my cd player but there is no harness and i can only identify the power wire. not one of the speaker wires are colored the same ....whats the easiest way to...
Here's the 89 Bronco radio wire color codes;
Constant 12V+ Green/Yellow --- Switched 12V+ Yellow/Black --- Ground Red or Black --- Illumination Blue/Red---
Dimmer n/a--
Antenna Trigger n/a -- Antenna Right Front--- Front Speakers--- 5" x 7" Doors--- Left Front (+)--- Orange/Green--- Left Front (-) Black/White --- Right Front (+) White/Green---
Right Front (-) Black/White---
Rear Speakers 6" x 9" Side Panels Left Rear (+) Pink/Green---
Left Rear (-) Pink/Blue---
Right Rear (+) Pink/Blue---
Right Rear (-) Green/Orange---
Feb 07, 2011 | 1989 Ford Bronco
I need an instruction manual to hook the speakers to my computer
There are no manuals for speakers. Speaker wires are color coded. Computer sound cards are likewise color coded.
the light green sound card mini plug port is where the green speaker wire is plugged in.
Pink is for microphone.
Black and orange sound card ports are for additional speakers.
Jun 28, 2010 | Boston Acoustics BA790 Computer Speakers
How do i hook up the speakers?
If your sound card has only pink, green and blue colors connectors in this case you will connect your speaker’s green cable into the green connector of the sound card. (Orange and black connectors will not be connected)
You will connect your microphone (if you have) to the pink connector of your sound card.
Please find the pictures which explain the color codes below:
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Logitech X-530 Computer Speakers
What do the 4 color coded openings in the back of the sound blaster card mean? What plugs into which opening?I've got a Dragon dictating system microphone that has different colors. I'm away from home whee...
Hi, I know of three of your colors which may be the following.
blue.....Aux port
green...Soud (use this for your Dragon sound)
pink......Mic (this will be use for your Dragon connection mic.)
let me know if it worked.
WBTech
Jan 14, 2010 | Dell Sound Blaster Card
What is the color coding of the connectors in SB Audigy 2 ZS video card?
red/pink is microphone in
green is line out to powered speakers, external amp or headphones
blue is line in
black is rear speaker out to powered speakers or ext. amp
yellow/gold is digital out to SPDIF/DAT
color code is known as the PC99 standard
Jul 14, 2009 | Creative Labs Sound Blaster Audigy 2 Value...
Had to cut the factory harness
trick of trade... take a 9 volt battery and touch the wires to it.. the speaker will pop and you will know which one is which... do one color at a time
Apr 21, 2009 | 1993 Ford Explorer Limited
I've just bought a desktop from Cube (the Polaris ST12) which comes with Creative Inspire T6100 5.1 speaker system. The connection instructions which come with the speakers show 3 cables from the subwoofer...
The blue is for a audio in and pink is the mic. Green is the audio out.
You will need to buy a new video card that has all 4-5 colors (green,,black,orange,blue,pink,white)
That way you can plug in all your connections and it'll work correctly.
Oct 23, 2008 | Computers & Internet
1988 mark 7 color code for sound system
1986-89 Lincoln Mark VII Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red Illumination Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) Pink/Blue Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Blue/Orange Right Rear (+) Pink/Blue Right Rear (-) Green/Orange
Aug 17, 2008 | 1988 Lincoln Mark VII
MSI 915o comboAudio front panel
Some cases come with a Mic & speaker jack/ cable. These jacks sit within the case. Rather than using the rear Mic which is (colored pink) & speaker (colored green). These 2 colored cables run from the front of the case & out through an emty hole in the back of the case. Which you connect them to the rear of the boards Mic in (pink) & sound (green). Now you can use your front audio jacks for both mic & sound. This may sound strange but I have come across many cases just like this. Its not uncommon to have 2 front usbs & a 1394 connect on to the board as well. Without your manual I'm sorry I can not help you fauther.
Jan 02, 2008 | MSI 915P Combo-FR Motherboard
Sound card installation
its at the back of your computer it is color coded, primarily green, blue and pink. the usual color for audio output is green
Sep 15, 2007 | ASUS TV FM Card 7135 (7135REMOTE) Video...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
