Question about LG RD-JT91 Multimedia Projector
Blue LEDs flickering
Thanks a lot for the quick reply - just to confirm - does the 4 centre blue LEDS (not die normal LED indicators) indicates main control board failure?
  • Altus Apr 29, 2008
    South Africa
    Cape Town
    Northern Side
  • hermesenmax Mar 05, 2009
    Marrie,
    I have the same blue lights falshing problem on my LG RD-JT91 projector. I could not help but read about your offering help to find a repairer for Altus in South Africa. Could you help me to find one to do so in Barcelona or Spain ?. Thanks a lot.
    rogerjimenez@coac.net
  • 563 Answers
Hi Altus , yes that is correct.
Which country are you in ? I will try and direct you to a repairer ?
Posted on Apr 29, 2008
  • Marnus Jacobs
    Marnus Jacobs Apr 29, 2008
    Hi Altus
    Ok , jy kan sommer vir Projector Repair Centre kontak by 021 555 2658 of Information Technologies by 021 4480650
    Een van die twee sal jou vinnig kan help !
Why Ariston lbf 51 lights flash rapidly
24501406-0h3kxpflbez5mdeb5anq3st4-3-0.jpg If flashing any of the 4 LEDs (see picture) means that the dishwasher discovered a malfunction. Depending which combination of LED flashes (one LED, two LEDs, three LEDs or all four LEDs) indicates the specific error code.
Dado
May 25, 2014 | Ariston Technologies Dishwashers
Error 8:11 HP Designjet T1100ps 44in PS3
Error indicates Formatter,Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part..
d4wd6icgpc9laaaaaelftksuqmcc
nloqafiqpfr0pqy6fgsl6z+nlcjwrqeuxlt5siey8sjpc+feblil6+xgwjruzafracof0e359teuwi1ozhlmhrx0xfmcd+bfeilmn5l+ppik2hpic6wgwvpqfwee1yw0nvg1qi9vzo58bnigp4octvkvtsy87834sjn6odbsmoha2eycmv8comsjb7raqh4aaaaasuvork5cyii=
May 03, 2011 | HP Designjet T1100ps Printer
When I turn on my plotter error message system error 08:11
* indicates "on"
# indicates "off"
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
Apr 19, 2011 | HP Designjet T1100ps Printer
I need to replace two blue indicator lights and I need directions
I have replaced several of the indicator lights in the control knobs.
Turns out that Dacor doesn't sell exact replacement lights (actually LED modules).
What I did was to go to a local electronics supply store and purchase Blue replacement LEDs and a current limiting resistor to connect in series. Replacement LEDs can vary in brightness depending on your taste ... I chose a super bright LED which makes the control knobs noticeably brighter. The value of resistor will vary depending on the LED you choose (brighter LEDs need slightly more current and as such the resistor value will be slightly less).
Once you've opened the range from the top (remove knobs, grates and burners) then remove a few screws and the entire unit opens with a hinge in the back.
Look over the LED light modules which shine just below each knob and fashion a replacement LED assembly.
Total material cost per LED unit was ~ $2-3 (LED, resistor, wire and heat-shrink tubing)
Jan 04, 2011 | Dacor 36 in.PGM365 Gas Cooktop
ERROR CODE 18:10
* indicates "on"
# indicates "off"
Nov 29, 2010 | HP Designjet T1100ps Printer
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
I have a lexmark e250dn printer. Today the printer has stopped working. The help ! indicator on the printer is an orange color as well as the toner/and drum indicator is an orange color.The ready indicator...
Here is how to reset the photoconductor kit counter:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
May 25, 2008 | Lexmark Office Equipment & Supplies
RD_JT 91/92 DLT Projector not switching on.
Hi Altus
This a common Mainboard failure on the LG JT91 if all the LED's flickers.
The good news is that it can be repaired. Much cheaper than replacement.
This will however have to be done by a Service Provider.
Apr 29, 2008 | LG RD-JT91 Multimedia Projector
LG RD-JT91 Multimedia Projector Logo
443 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
