I have Belkin Ni wireless modem router. I would like to change the name of my network. How do I do this, please. Don't be too technical, please.
  • 62 Answers
It is not hard to change the name of your wireless network. Well, not hard as long as you have the IP addy for the router and you have the log in and pasword if it is pasword protected. Simply put in the router IP address in your Internet Explorer window like a web addy... most times the addy is 192.168.1.1 If your router is pasword protected it will bring up a login window. Put in the login and pasword and you are in. The main page will list all the information on the router including the name of the network, simply change the network name and then save the changes. And presto bango. Hope this helps.
Posted on Apr 29, 2008
Verizon network extender netgear
please contact Verizon's Premium Technical Support and ask assistance for port forwarding if you want to use another router to your Verizon's network.
please contact 1-800-567-6789 and ask for Premium Technical Support.
May 15, 2012 | Westell Wirespeed Westell 7500 Dsl Modem...
Tip
To Change the Security key or the Network key in your Belkin Wireless Router?
Hi Friends,
Please follow the default steps for all the belkin wireless routers to change the Security key or the Network Key in the wireless network
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Security,it will prompt for a login password,leave it blank and click on Submit.
Step 5:Now change the Security type to either WEP or WPA
WEP:
If You select WEP (64-bit), then you will be able to see 5 small boxes ,in each box in key 1,type 2 numbers in each box only in Key 1,after you have typed the number please make a note of it and click on Apply Changes
WPA:
If you select WPA,then you will be able to see the Preshared Key or Password (PSK),in this place type as thing as you wish,after you have typed please make a note of it and click on Apply changes
Step 6:On your left hand side click on Channel and SSID,now you will be able to see the SSID name,Change it any name as you wish and click on Apply Changes
Step 7:Now go to the wireless Computers and try to connect to the new network name,when you try to connect ,it will prompt for a Network key or Security key,type the password which you gave in the belkin router page
The above mentioned steps are the default steps in all the queries if any customer need to change the security or the Name of your network,you can follow the above steps.It very simple and easy to understand
Regards,
Ayyasam
on Mar 17, 2010 | Computers & Internet
How To Use a Belkin Wireless G Router as a range extender? I'm trying to hook my Xbox to the internet, the problem is that the xbox isn't wireless and internet comes from a wireless modem and is...
You can Convert the Router as an Access Point But your Wireless Modem Should Be Hard wired to router. But if your Router has an wireless Bridge Option in it you can Convert it as an Range Extender. Check For the Wireless Bridging Feature on your Router or Please Post your Router's Model Number Here. I Will Be Glad to Help you out... :)
Mar 12, 2011 | Belkin N1 Vision Wireless Router
I just bought a new Belkin Surf router. We went through all the steps the start-up cd says. But it keeps asking for a security key. Where can we get that?
Hi i got your issue .......
Please try with the following steps ......
Step 1 : Connect modem -Router - Computer ( Wired)
Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 2: On the left under wireless click wi - fi protected setup
Step 3 : Leave the password blank and click on submit
Step 4: Disable it and Click on apply changes
Step 5: On the left under wireless click Security
Step 6 : Enable 64 Bit WEP
Step 7: Type a 10 digit number on the key 1 ( 2 in each box )
Step 8 : Click apply changes
Step 9: on the left under wireless click channel and SSID
Step 10 :Change the Wireless channel to 6
Step 11 : Change the SSID to a different name ( no Spaces )
Step 12: Click apply changes
Step 13: Now Scan and connect to this network ( Wireless )
If problem still presists please contact 24/7 belkin technical support 1800-2235546
Oct 06, 2010 | Belkin Computers & Internet
I've been using the Belkin N1 router using it for my wireless connection for almost 3 years now. But only last night, the wireless light is out, and the security light is out as well. I've tried unplugging...
I think the power cable of your modem has been damaged. kindly check the power cable. If there is no light on the modem , it is assumed to be that the power cable has been damaged. so you have to purchase the power cable of the modem. If the power cable is found to be perfect , kindly purchase the net work cables/ OR prepare the net work cables if you are aware of about the network cables., because the clippings of the network cables might have spoiled. If the power cable of modem, network cables are found to be perfect , it is certainly , the modem might have damaged. To fix the all the problems mentioned above , you are requested to to contact your ISP ( Internet Service Provider) . They will certainly fix your problems. In the mean while kindly try to solve yourself. If you are paying rent towards the monthly charges against the modem to ISP , they must be replace your modem with new one. If you have purchased the modem by paying the cost of the modem at the time of installation of the internet connection , you have to purchase the new modem, if the old modem was found to be damaged.
Oct 03, 2010 | Belkin (F5D8231-4) Wireless Router...
I for got my wireless password how do i find out what it is?
Hi Friends,
Please follow the default steps for all the belkin wireless routers to change and to get the Security key or the Network Key of the wireless network
Step 5:Now you will be able to see the Security key or Passphrase,this is your wireless network password
Regards,
Aysaam
May 26, 2010 | Belkin (F5D7231-4) Wireless Router
Xbox live
Some modem have built in router.So in my case i have hughesnet hn 9000 modem so what i did is connect my modem to a switch and from your switch connect to your xbox live. so buy a switch.
Feb 14, 2010 | Belkin (F5D7230-4) Router (587009)
Setting up a belkin n wireless router. How do I
You have to go into the setup for the router. Most default to the 192.168.1.1 IP address. You would type that address into your internet browser and hit enter. Then you will be asked for a name and password. If you have your belkin manual it will tell you the default name and password. Once in the settings you can change the password. You can also turn off SSID broadcasting, enable the highest level of security that your particular router supports in conjunction with your computer and enable MAC authentication. If you enable MAC authentication you have to type in the MAC address for each device you wish to have access to the router.
Nov 07, 2009 | Belkin Computers & Internet
Router Security Light is Blinking
I have the same symptoms. In my opinion, this is done because you turned your Belkin from a router to access point position. I did it also (issues with adsl modem/router). By manual the flashing diod means no secure device. But, without pass you can't access your Belkin. So, probably, some fault in firmaware.
Nice day.
Oct 26, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
