Question about Soltek SL-KT600-RL Motherboard
Checking NVRAM.. My SL-KT600-L has recently decided to hand at 'Checking NVRAM..' This happens only on the first cold start. After depowering and starting again, it starts normally.
  • Pierre Scerr Apr 30, 2008
    Thanks for your reply
    I took out all 3 RAM sticks and all the PC cards and put them back in again. Still the same. First cold boot - stops at 'Checking NVRAM'. Switch off and on again and it works.
  • Pierre Scerr May 21, 2008
    I reseated everything that could be reseated, but it still hangs at 'Checking NVRAM..' on the first cold boot.
    Problem Solver:
  • 8 Answers
Try reseating your ram and video card. could be that you have a bad connection somewhere on a socket or port. and once everything warms up the contact becomes better. if that doesnt work reply to this and i'll keep my gears turning
T0X1K66O
Owner, Founder, Head Technician
Leading Edge Computers LLC
87supra2jz@gmail.com
Posted on Apr 29, 2008
  • Filippo Moreci May 21, 2008
    hmmmmmmmmm. have you remounted the mobo lately? Try replaceing the coin cell on your bios and check your settings within the bios regarding memory testing. I have a soyo p4vtp that has a similar issue that is in my shop right now. and bad bios was causeing the testing in the begining to mess up here and there. you might need to upgrade your bios. maybe you can just disable the test in the p.o.s.t. all together through the bios. besides thati am out of suggestions
Cannot connect to network. It show IP address 0.0.0.0
contact your service provide for assistance on how to set it up
Apr 28, 2015 | HP LaserJet P2015n Printer
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
4 Release the GO button.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
NVRAM initialization
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
To perform NVRAM initialization
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Jul 30, 2011 | HP LaserJet 1300 Printer
My car won't start. It's cold. Battery acting funny. But, jump start failed to get it going. What do I need to start it again?
if you can't jump start it in the cold bring battery into warm place and put it on a charger.the cold is an enemy of batteries. but this might happen again battery sounds like its weak, unless car has been sitting in cold for long time.you can get a new battery for about 60 dollars have all your problems solved.
Jan 07, 2010 | 2002 Saturn Sl
Probs with boot up on a Dell inspiron 530s
When booting enter the BIOS setup svreen and press the following combination
1. Alt + E
2. Alt + F
3. Alt B
this combination will rebuild the IDE configuration and clear the NVRAM. Alt + b will save the configuration.
Alternatively
1. Shut down PC and unplug Power cable from Back of Tower.
2. press the power button and Keep holding for 10 seconds. this will remove static charge from PC
3. Plug in cable and restart.
Jan 13, 2009 | Dell InspironTM 1501 Notebook
SL-KT600-C1L Motherboard
unfortunately soltek has gone out of business, so you can no longer find the manual.
Oct 21, 2008 | Soltek SL-KT600-C1L Motherboard
HP 2015 clear password
I would try the cold reset again. From the service manual :-
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
Sep 10, 2008 | Office Equipment & Supplies
Problem with starting
Sure , there is a way to test it ! With wiring diagram in hand an a DVOM - digital volt ohn meter . Checking B+ voltage to the switch an output on the start - run circuits ! Do you know anything about automotive electrical systems ? How to use a DVOM ? How to read a wiring diagram . Too know how to take it apart you need a repair manual . Videos on youtube showing how too test electrical circuits
Jun 05, 2017 | 1997 Saturn SL
One Beep after Checking NVRAM...Update OK
The Computer generates 1 beep. to state that the computer has set itself up properly, without errors. Depending on the bios manufacturer. i.e Pheonix or AMI et,c.
As long as your system is running fine with no crashes or errors.
Then this seems perfectly normal.
Feb 17, 2008 | Soltek SL-86SPE2 Motherboard
Soltek SL-KT600-RL Motherboard Logo
615 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
