SX-1600 + KD-491F
Thank you for your quick response. Just so you'll know, I also have 4 S-DF1-K speakers: 15-100W, 8 ohms....a PD-F407 CD player....a Pioneer CT-300 dual tape deck. Want something that will run all of these plus the KD-491F. Thanks again. KB
    Brigadier General:
  • 6,966 Answers
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Posted on Apr 29, 2008
Hello, I have an old SX-1600 stereo receiver that has a short in it. Shipped off once already to be fixed. It worked ok for about a year. Now, it's doing the same thing. Don't know where to send it...
Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
Will scout around for receivers and post back additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 29, 2008 | Audio Players & Recorders
Is it totaly ok to just connect one pair of JBL Control 1 speakers to this receiver? Here are some of the specs. Frequency Response: 120 Hz to 20 kHz Power Capacity: 150 W Sensitivity 87 dB SPL Nominal...
The only relevant speaker spec is the impedance. As you probably realize the Pioneer SX-255R recommends 8 - 16 ohm speakers.
Four ohms is on the hairy edge of too low. You could certainly try it but if any strain or excessive volume is used you could see something go poof!
The low end of 120Hz says don't push the bass to them.
Jul 14, 2011 | Pioneer SX-255R Receiver
Ohms speakers for jvc kd-lx100 cd player ?
Hello miltonmelgar,
According to JVC, you can use either 4 or 8 ohm speakers. This would seem to indicate that the internal amp is not stable below 4 ohms.
Here's a link to the manual. The information is on page 29 under the "audio amplifier section" and shown as "load impedance".
Hope this helps.
Oct 12, 2009 | JVC KD-LX100 CD Player
Run 4 ohm on yami 1600
The manual says...
"If you are to use 6 ohm speakers, be sure to set the "SP IMP" to "6 ohm Min" before using this unit (see page 30). 4 ohm speakers can be used as the front speakers (see page 118)." ... which basically says the same thing in a table.
Set it for 6 ohms and try ity out. If it exhibits any problems like the amp cutting off you might want to lower the volume or analyze it to see if the 4 ohm guys are the problem.
BTW: That spec is just a nominal value. At various frequencies every speaker's impedance changes. The proof is in the pudding. The Yami won't self destruct unless you crank it to the stops and ignore the audible warnings of stress.
May 18, 2009 | Pioneer SX-205 Receiver
Inpedance button ???
The impedance button allows you to toggle between 4 and 8 ohm speakers. By default, most receivers are designed to run an 8 ohm load as this is the most common draw from home speakers. However, a few may exist that require a 4 ohm demand (many Bose for example). Or, if you have two 8 ohm speakers connected to a single speaker terminal, the impedance will drop to 4 ohms for that channel. In your case, you most likely have a regular pair of speakers with an 8 ohm impedance. In this case, the button out (8 ohm) will do the trick.
May 03, 2009 | Audio Players & Recorders
This is not a pioneer vsx-454 receiver problem
I would not recomend doing this because the 4 ohm speaker is not enough to offset the 32 ohm speaker and the amp will have problems keeping up with the power consumption of the speakers and will eventully overheat and cause damage! (it will work but not well and not without risk to your amp!)
Please rate this quick response
Thank
You!
Jun 19, 2008 | Pioneer VSX-454 Receiver
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
My Pd-f4o7 25 CD changer
Mechanical fault, monitor loading arm but most likely belts.
capital98
Dec 19, 2007 | Pioneer PD-F407 25-Disc CD Changer
258 people viewed this question
 Grubhead
Grubhead
