Question about Hotpoint Aquarius WMA42 Front Load Washer
Door lock light flashing
Hi.
Machine cycle won't start, it just beeps and the red lock sign flashes.
Any ideas?
I have a Hotpoint WMA34 (1000 Spin). The appliance stopped mid-way through a cycle because of an electrical fault. I changed the power source (making sure it's the same ampage). I unloaded the machine, dried out the water, and powerd up the machine. The machine powered up, but the cycle did not start. Instead, the "door-lock" button started flashing.
  • 6 more comments
  • Anonymous Aug 16, 2008
    exactly the same prob for me!!!
  • julianandcla Aug 31, 2008
    i have he same problem but with wma64 , i switch off power the door releases. then when i try to restart a progrm althought door is physically closed the light continues to flash and wont start a program. However occasionally i have used the sequence and the door lock works fine and i get awash done....?? if its only occasional does that mean the main boardis ok and it si just teh door lock ??
  • salvas Oct 12, 2008
    i have the same problem. but my boyfriend replaced the door seal as my ferret got in and bit a hole in it. he put the wires back on the wrong way and fireworks were coming out the side. his friend had a washer the same that he was getting rid of so he got the mother board an put it in mine. it worked for the first wash but now the door lock light flashes and the wash just doesn't start. he said it might be the doorlock so i bought a new doorlock and still nothing. what next ? will it cost much to have someone look at it or should i just buy a new machine
  • john silver Jan 26, 2009
    machine worked half way through the cycle it never released the water or went past it cycle position. there was a bang and smoke from the machine.currently the door lock light flashes but goes no further
  • Shaf Ahmed May 11, 2010
    Best Solution
    posted on Dec 09, 2007
    WASHDOCTOR
    Rank: Guru
    Rating: 87%, 146 votes
    either its the door lock or the circuit boards is blown
    TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
  • as004a2267 Aug 06, 2010
    i have turned the wash cycle today and all i get is flashing lights with non of the wash cycles working? please help
  • Anonymous Mar 22, 2014
    My machine won't start a cycle anymore and the lock light flashes. Can this be fixed or should I just cut my losses and buy a new one?!
  • Anonymous Mar 27, 2014
    Machine starts working as normal then partway through the program the lights start flashing the machine stops with the door locked
Hi
I have a hotpoint wma34 washing machine.
The problem that I have is the old door switch dosnt work when the door is closed. If, for example i set the washing machine on setting K and run the machine the 'door open' LED flashes.
If I then remove the switch and press down on the microswitch on the door switch the machine starts working normally.
I have done about 20 washes doing this and everything works fine.
Now, i have ordered two replacement switches tha wnt work at all. They look the same as my original but there is no microswitch on the door switch (if tha makes sense?) and the dont work at all.
So, what can the problem be.... any clues ...?
Thanks
Posted on May 11, 2010
  • 139 Answers
Best Solution posted on Dec 09, 2007 Door lock light flashing - 3%20stars.png
WASHDOCTOR
Rank:guru_s.gif Guru
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
Posted on Aug 20, 2008
    Scholar:
  • 116 Answers
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
4 Suggested Answers
cerikitten
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
  • 139 Answers
SOURCE: Door lock light flashing
Shame to say it but yes..
You board behind the control pannel is blown. this is caused by either a faulty door swtich or the motor.. Your model number tells me its most likely the door switch.. The control board will need replacing and the door swtich.
Getting to the board is easy only three screws near the soap draw. make sure you write which wires go where and to getto the door lock undue the door rubber if you needany further advice let me know
i have worked on more the 300 of these machines
Posted on Dec 24, 2007
beltronic205
  • 1474 Answers
SOURCE: The door locked light keeps flashing on my
Sounds like needs new door interlock swith Cost around 15 pounds.....Simple to fit
Posted on Sep 28, 2009
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Hi there, My washing machine is hotpoint WTL500
My washing machine runs for 10 minutes then all the lights start flashing also there's water in the drum, I've drain the water twice but it does the same thing.
Any idea what's going on there pls.
Aug 11, 2013 | Hotpoint Aquarius WMA42 Front Load Washer
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Hotpoint first edition washing machine door will not open after completing its full cycle
hi from the uk susan ? this is not uncommon and easily fixed if you are confident DIY ? and req's a little patience with a posi drive screwdriver if you want to save $$$$s on call out fee ? the problem is most probably the time delay switch which prevents door opening too soon after cycle/machine has finished and the light has gone off then door can be opened if you feel confident ? will help/instructions on how to rectify fault if you reply back ?
Apr 15, 2009 | Hotpoint First Edition WMA12 Front Load...
Door locked light flashing when door is closed
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine not working
I Put A Set Of New Brushes In motor And It started
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dec 24, 2007 | Hotpoint WMA76 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
4,010 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
