Question about Cameras
I connect my Fujifilm s3500 to my computer through the USB port to download pictures and it says that device has malfunctioned and windows does not recognized it. I connected it up last week and I had no problems. Can you suggest anything? I have ensured that the device is enabled.
  • 3 more comments
  • bcpearse Apr 30, 2008
    I tried your suggestions but they didnt work. I still have the same problem
    The camera is a fujifilm S3500 camera with 6x optical zoom 4.0 mega pixels model no: 5DL05953. I think it may not recognise the software in the camera. How can I change this?
    Thanks, for that. I did everything you said, but there was not program installed for my camera, so I couldn't uninstall it. I gave it a clean boot. And installed the USB driver for fujifilm finepix s3000 that you directed me to. This was successful, however, the computer is now saying that it does not detect the camera. My camera is a finepix s3500, would that make a difference? I do not think that I have software for this camera. I don't remember installing any from a disk. Also I notice on my camera screen when I connect it to the computer there is a DSC green band halfway across the screen which has always been there, but now there is also a little USB symbol in the top left hand corner of the screen which never used to be there? Can you still help me?
    Thanks ginko, I did disconnect camera from USB and PC power cable for nearly 20 min, removed the batteries and the memory card, cleaned all the ports, and it still doesn't pick up my camera. I would reinstall software if I had any, but I honestly don't remember intalling it and I cannot find a disk for it.
    When I connect the camera to the computer the removable disk (F:) box comes up and I select copy pictures on my computer using microsoft Scanner and Camera Wizard. I normally used this program. I select it then it says...Windows cannot detect your scanner or camera
    President:
  • 2,712 Answers
Hello bcpearce,
It could be that your driver is corrupted.First download the latest driver for your camera from HERE
DONT INSTALL IT YET! Lets do a clean boot/install. This procedure is done to avoid conflicts with other software during installation:
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next , do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 30, 2008
  • 3 more comments
  • Swilin Sampson
    Swilin Sampson Apr 30, 2008
    In order to resolve this issue, please see Microsoft Article 838989 to obtain the patch file for USB devices that won't detect after a power cycle and the Microsoft Article 822603 for the patch file for USB devices in Windows.
    NOTE: You do not need to download these patches if you have
    installed Windows XP Service Pack 2.
    Try using a different
    USB cable, if possible and check if it works.
    If all else fails, just
    use Windows Explorer to transfer files between PC and camera. (Right click
    START and select “Explore”). This would be the easiest method.
    Let me know how it goes.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Sorry bcpearce, I gave you the wrong drivers by mistake, my apologies. Please download the drivers for your S3500 camera from here: Fujifilm FinePix S3500.
    Use the same method of installation as I outlined in my first post,ie, clean boot for best results.
    Also make sure that you are connecting the camera directly into the USB port and not through a hub or port replicator, as that can cause detection issues sometimes.
    Let me know if it works..
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 02, 2008
    Just checking to see if your issue has been resolved… If
    please take a moment to close the ticket with a FixYa! rating under my
    solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 12, 2008
    solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 14, 2008
    You haven't yet rated the solution :)
  • Cameras Master
  • 19,396 Answers
Disconnect camera from USB and PC power cable from outlet (turn off is not enough, unplug) for about 10 minutes. Then reconnect.
This will get rid of lectrostatic charges on usb.
If is not the above reinstall software
    Genius:
  • 1,447 Answers
Hen you plug it back to your computer, go to device manager by right clicking on your my computer icon, then properties and click on hardware tab and device manager, look for conflicts (?,! or X mark) right click on it and update it then select next. if there is no conflict look for imaging devices then look for cameras name, and right click and update.
If that doesnt work tell me if you encounter an error message...
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 30, 2008
    USB is not generating enough power to detect your camera, have you tried using a different usb cable or using the front USB port on your computer? when you plug it in normally you should get a found new hardware wizard window, make sure you directly connect it from camera to computer...
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 29, 2008
  • Maanita Chadha
    Maanita Chadha Apr 29, 2008
    1.Please take the battery out of the camera
    leave it turned off for 10-20 minutes. make sure there is no power attached to the camera. then take the memory card out as well. insert the memory card back again and the batteries too.
    2.recheck the usb port. that might be dirty due to dust. use an ear cleaning swab. Dip it in alchol and clean the contacts of both the usb cable and port.
    while you do that make sure that the power is off.
    try using the camera and let me know the status
    thanx for using fixya
    dont firget to rate fixya
Why won't the driver for my fujifilm finepix AX300 install on windows vista?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Oct 21, 2012 | FUJIFILM FinePix AX300 / AX305 Digital...
Unable to download a picture after connecting usb cable to computer
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jun 01, 2012 | FUJIFILM Cameras
Plug my camera into the usb port, computer doesnt recognize it
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 25, 2009 | Samsung S860 Digital Camera
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
USB device malfunction
i) try to connect pendrive to the usb ports present at backside of ur computer tower instead of usb ports present at the front panel of ur computer...............
ii) sometimes usb ports present at the front panel ofur computer might have loosen connections............
Thanking you
M. Sridhar
Jan 18, 2009 | Intel Motherboard
I have connected my FinePix digital camera to my Windows PC and I still can't view the images on the SmartMedia or xD-Picture Card. What should I do?
If the images on a SmartMedia or xD-Picture Card fail to appear when the camera is connected to a Windows PC, one of the situations listed below may apply. 1. There may be a problem with the SmartMedia or xD-Picture Card. Check that the images can be viewed on the digital camera. If the images cannot be viewed on the digital camera, gently wipe the gold colored contact area on the SmartMedia or xD-Picture Card with a soft cloth and then check again. 2. "PC Camera" may be selected as the USB setting on the digital camera. Change the USB setting to DSC or select DSC in USB MODE. * This only applies to models with a USB Setting or USB MODE option in the SETUP screen. 3. Does the LCD monitor on the digital camera show that the USB connection is active (USB, DSC or a USB symbol with an arrow is shown on the LCD monitor)? If not, the digital camera and PC may not be connected correctly. Check the items listed below. a) Restart the PC and reconnect the USB cable. b) If the PC has multiple USB ports, connect the cable to a different USB port. If steps a) and b) have both been tried and there is still no USB connection indicator displayed on the LCD monitor, there may be a problem with the digital camera or USB cable. Contact an authorized Fujifilm service center and ask them to check the digital camera together with the USB cable. Refer to the Digital Equipment Repair page for information such as the procedure for requesting checks and the locations of authorized Fujifilm service outlets. 4. The USB driver may not be installed correctly. Download the USB driver from the Fujifilm general downloads web page and re-install the driver. 5. The card may not be recognized correctly if the camera is connected to an added USB interface board or via a USB hub. Always use a factory installed USB port and connect the camera directly to the USB port on the PC.
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
