Thank u Hi, Thank u 4 ur help. But inspite of checking BIOS, Cables,, etc., As a result i entererd in net.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Try redownloading from www.slysoft.com
you try it for 20 days and you can burn rewrite and download just about any kind of dvd cdrw you want lala linda
Posted on Jun 03, 2008
Snowy picture since 8 May 2012 Through vcr
in ur case snowy pictures occurs when ur cables are moist resulting to a grounded circuit check both ends of d cables for wets if in case have the cable dried at least the whole day or replace for best results.or on the other hand check ur tv system mode it might be in the wrong system compliance in ur area or just rechannel ur vcr set to auto program/tune.
May 09, 2012 | Televison & Video
Re: HP Pavilion m9150f - Need hardware solution for bios reset
just restart ur bias...by just reinsert the battery in motherboard...but it lead u to delete all ur datas in it...
Oct 27, 2008 | Computers & Internet
Dell Inspiron 6400 laptop with win XP - Onmce I close the lid and then open it, display will not come up inspite of pressing keys (Fn .., Power key etc)
This has been an on going problem with several different models of Dell computers. It appears to be a problem with the on board video itself. A few possibilities;
double check your memory including checking for memory conflicts.
try turning your screen saver off, this helps with many of the computers with this problem.
set your virtual memory2_bing.gif to a fixed size, about 4 times your RAM + 12MB.
check for a corrupted BIOS2_bing.gif.
temporarily turn down or off any video accellerators.
check the moterboard for bad solder joints, note these are multi layer boards so bad solder joints are very hard to repair.
check with Dell they may have resolved the problem at last.
Jun 14, 2010 | Dell Inspiron 6400 Notebook
Problem to connect net with mobile
check ur gprs settings from ur service provider u will get a positive result...
Sep 04, 2009 | LG KG800 Cellular Phone
Every time i try to turn on my bluetooth it comes up as 'already activated' even if it isnt or the whole phone freezes. Any help?
Try to format ur cell phone using the code *#7370#.
It will be like a master format & it will definately solve ur problem. Inspite, U need to take the backup of all ur data like Contacts, Messages etc. U can easily pursue it via Nokia PC suit.
Hope it works u out of it...
Aug 26, 2009 | Lands Phones
Web cam
You try to get some details of ur web camera ,what type of driver will it support ,etc. Then try to download the suitable one with compatible version.
Jul 10, 2009 | Computers & Internet
Can't boot
i should have thank u, if u add some more details in ur query, anyway check the following :
1. check if ur power cable is properly connected and free from damage or broken
2. did u see any blinking indicators on ur front panel
3. open the cabinet and look if the fans are spining
4. did u hear any beeps during (POST) startup
***** if ur answer to the above is YES, then
remove all the power connectors (outside and inside) , all the add on cards, RAM sticks, (and also the processor if u have a pair of smart hand), carefully clean and blow out dusts, and reinsert all of them to thier respective places, and try again.
If u find all these solutions useless, ur processor or RAM or mainboard might defective.
May 06, 2009 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Pc not on
Please list the name & model number of the motherboard.
M
Jun 09, 2008 | Computers & Internet
Pc does not boot
my pc is asrock m266a board intel pentium 4. it does not boot nor reach to bios startup nothing shows on the monitor ketbord and mouse are off only the fan runs i tried to take everythin out and assemble it again no results found pliz help . moses
May 07, 2008 | Asrock M266A Motherboard
Any other advice?
hi....
this trick will allow u to use ur usb stick as a key to boot into windows . if someone tries to start the
computer without the usb stick , it will display boot errors. before we begin , let me tell u that playing
with the bios and boot files of ur computer may result in u not being able to boot into ur windows partition ; so continue at ur own risk!
step1: unhide hidden and protected files: go to tools > options > view , check show hidden files and uncheck hide protected system files
step2: from the drive where windows is installed copy the files boot.ini,ntdlr and ntdetect.com to ur usb stick
step3: now we need to go into ur bios , so restart and keep jabbing (F8 or DEL) as soon as the pc starts
step4: once the bios , enable usb drive as the first boot device u might have to enable usb legacy support on older bioses
step5: restart ur pc if all goes well , u should be able to log into windows if not, then unplug the usb stick , return to the bios and change the first boot device to ur hard disk drive and repeat the steps above
step6: once u r logged into windows , go to ur windows drive and rename boot.ini to boot.bak
step7: to check if u have setup everything correctly , eject usb and reboot the pc u should get error message on the screen such as "invalid boot.ini" or " windows could not start "
step8:incase windows does not load , use ur windows recovery disk by followin the steps at http://tinyurl.com/s9sd2
Apr 14, 2008 | Intel D850MV Motherboard
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
