Question about LG DLE5932W Electric Dryer
Takes two cycles to dry anything - even on High
Even though I've followed the manual's instructions to wash the lint screen (to remove softener buildup), it still can't dry a load in one cycle. The clothes come out warm when they finally ARE dry, so I know it's at least heating... but why does it have to take soooooo long?? I dry EVERYTHING on high, and count on it requiring two, sometimes even three cycles.
  • Anonymous Sep 23, 2008
    I have a similar problem
    Champion:
  • 210 Answers
Check your venting going outside. Make sure there is no blockage. Are you overloading it?
Agt 48
Posted on May 31, 2008
  • 78 Answers
First, check your breakers for the dryer. turn them all the way off and then back on. if it still doesn't work right, it needs to have all the lint cleaned out of the exhaust hose, and then the inside needs to be cleaned and the heating coil examined for damage.
Posted on Apr 29, 2008
Why would my washing machine leave a bunch of dark particles on clothes that look like pieces of dirt or leaves?
This sounds like what the service manual calls "scrud":
"If fabric softener is used regularly it will eventually cause a build up within the outer basket. This can result in black flakes present in the wash load that can stain garments. To remove scrud follow the procedure below.
Step1: Add a full cup of a good quality dishwashing powder in to the machine.
Step 2: Set the machine to a Heavy Duty cycle, select a Hot Wash temperature, High Water level and allow the machine to agitate for 10 minutes.
Step 3: Leaving the lid closed, turn the machine off and allow to soak overnight.
Step 4: The following day, turn the machine on and advance to the spin cycle to drain the water from the machine. After the water has drained, turn the machine off then back on again, and select a Heavy Duty cycle, Hot wash, High Water level, and allow the machine to complete a full cycle to ensure that all of the loose scrud and residual detergent has been flushed away.
Note: If there is an extremely heavy build up the above procedure may have to be repeated." (emphasis theirs) (http://www.applianceaid.com/pdf/517792A-PH7-USA-Eco-Washer-Service.pdf)
You said you cleaned the machine already, so maybe you did this step, but I thought it might help.
Oct 27, 2015 | Fisher Paykel EcoSmart GWL15
Tip
Saving money drying clothes
The biggest thing to remember about your clothes dryer is that it has to get the moisture out. If you keep your venting clean it will aid your dryer in shorter drying times. The more heated dry air it can pull through wet clothes while they are tumbling the faster clothes will dry.
If the venting is restricted by lint or kinked, or low quality venting, all end up costing more in drying times. Use good venting, preferably steel, and do use the proper vent cap on the outside wall.(check lint does not catch here also)Many service calls could be prevented by regular maintenance of venting.( thermal safety fuses which all dryers have are the reason for most service repair calls when the venting has not been cleaned) Also the shorter distance your dryer is vented, the better.
The second less obvious problem is not cleaning the lint screen. All the air or almost all passes through this screen before being exhausted outside. You need to clean the lint first. Second you need to wash the lint screen in the sink to clean off any build up of fabric softener that can also cause slow drying. Water should run straight through the metal mesh, if it ponds it is coated with softener, and water should wash this off.(I have been on service calls where dryers were not drying correctly and just washing off the lint screen of fabric softener fixed the problem)
Lastly wiping the two short parallel bars about three inches long found inside the dryer with alcohol to remove any fabric softener or other coating will keep the automatic cycle working right.Not all dryers use these........
Before thermistors, when thermostats were all that was out there.........
Hope this saves you some money and time.......
on Feb 23, 2010 | Dryers
Electric dyer stops mid cycle Whirlpool
It could be the lint screen needs cleaning, and not just removal of lint, but washing with warm water and a soft brush to remove fabric softener / static cling sheets that can build up and without being obvious, clog the screen. If there is not adequate air flow and the dryer is over heating it may shut itself off as a safety precaution.
Also, i'm not sure about this model, but many dryers have moisture sensors. These can become ineffective do to fabric softener sheets build up that coats the sensors. Check the owners manual and locate the sensor. It is just two metal contacts inside the dryer. Clean them with warm water and a nylon scrub pad, like you would use to wash dishes, but not steel wool or anything too abrasive.
Apr 12, 2014 | Dryers
My clothes are covered in lint
Hello Pam, Take the lint screen over to the sink and gently wash it in dish soap and water. Let it dry and try it. Sometimes the small holes in the lint screen plug up from using fabric softener and/or fabric softener sheets. It doesn't take much to restrict the airflow through the lint screen.
Feb 14, 2014 | Samsung DV330AE Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Our new lg dryer model #DLE1310w is not drying properly. We have 6 medium side towels that are not very wet in the dryer even on the hottest setting it is taking two cycles to dry the towels. When we...
Recheck the vent all the way to the outside and make sure the vent hose is not smashed behind the dryer.
Long time to dry complaints almost always are due to a restricted vent.
Remove vent to dryer and test a wet load if they dry ok then the house vent is at fault.
Jan 17, 2010 | LG Dryers
LG DLG3788W Gas Dryer: dry cycle takes too long. It doesn't seem to get very warm at all. The lint trap is clean and the vent pipe as well.
Try vacuuming the burner exhaust and intake pipes of their lint collection. If these passages are partially plugged, the burner will short-cycle and not provide proper heat. Try washing the lint filter in hot water and detergent to remove fabric softener deposits. Hope this helps.
Nov 28, 2009 | Washing Machines
My kenmoore dryer takes two cycles to dry the clothes
Increase the airflow by vacuuming all air passages including the hose to the outside vent. Remove the lint screen and wash it in hot water and detergent to remove the fabric softener deposits. If still slow drying, there may be one of a double set of heating elements that is burned out--the drum must be removed to check and replace.
Nov 03, 2009 | Dryers
I've got a fridgedaire gallery gas dryer, approx 8 years old. Takes too long to dry clothes. I've cleaned inside as best I could and the dryer duct. Is seems to get hot some of the time, but not constant
if you use fabric softener. i recommend you slow it down...alot. an appliance guys nightmare is just that. inside fabric softener, is wax. your lint screen may look clean. but run it under hot water. ive come across many a lint screen where the water will simply not go through the screen, even though it appears to be sparkly clean.
Sep 29, 2009 | Frigidaire FGQ332ES Gas Dryer
Kenmore Dryer, Model # 11063102100, does not dry.
Does the drum still turn. If so probably just needs a new heating element. VERY easy to replace. Usually instructions to replace on or in new element box or just google instructions.
New heating element would be my first move to repair dryer.
Also, if you use softeners or dryer sheets, Wash lint screen with dawn and soft scrub brush to remove oils and residue (even if it dont look like there is none there there is) to extend your heating element use.
Sep 26, 2009 | Dryers
LG DLE5932W Electric Dryer Logo
289 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
