I want to connect my monitor which has a vga connection via a cat5e cable to my security camera which has a bnc connection on it
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    ok..so what's the issue? what do you wish to connect your monitor to?
    Brigadier General:
  • 6,966 Answers
With the indulgence of IB4G2008...
Not possible without a converter adapter at the same time signal losses, interference and noisy video if CAT5E cable used.
What I would suggest is to use coaxial cable (RG59) instead of the CAT5E. One end would be terminated with ta BNC male to connect to the camera. The other end would have to be terminated either with an RCA male. Before connecting to the VGA (15pin) input of the monitor, it would have to be processed by a converter/adapter. Here are some examples:
1. Composite Video to VGA adapter;
2. some high end adapters are shown here;
3. several shown here would also work.
In case you would like a DIY, this might interest you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 29, 2008
Wiring diagram for swann pro 642 camera
I don't know what you are doing with cat5 cable, according to the Swann Pro-642 manual
http://www.swann.com/downloads/product/2187M642CAM270212E.pdf
this camera uses a BNC connector on a RG-58 co-axial cable.
Installing BNC Connectors
Feb 23, 2017 | SWANN Home Security
How do I connect my camera up using cat5 cable
Please give the Model no. of the Camera.
generally if it is an IP Camera it can be connected with a CAT5 Cable to a computer.
If it is a non-IP Camera it can be connected with a Coax Cable to a Monitor.
Nov 05, 2014 | Swann Communications Home Security
How do I connect my network recorder to my outdoor network camera's ?
Most security DVR's come with software that control the cameras. Most DVR's use BNC type connectors and unless you buy a wireless system, you will have to run cables for them.
Aug 17, 2014 | Computers & Internet
I want to connect a 6 pin s video to a bnc monitor and cant find a connector
SORRY YOU CANT DIRECTLY CONNECT A S-VID CONNECTOR TO A COMPOSITE BNC VIDEO INPUT , THEY DO MAKE CONVERTERS FOR THIS (GOOGLE IT) BUT IT'S BEEN MY EXPERIENCE THAT COST OF NEW/CORRECT MONITOR IS LOWER/SMALLER THAN THESE DEVICES
Jan 31, 2013 | Lorex Home Sentinel Wide Angle Security...
Where can Ifind help for installing a Ouku brand 4 channel cctv dvr?
I had exact same problem and it took forever to fix but I did fix it. If I plugged the camera into the tv it worked but when I tried going through the dvr no picture at all. The problem was the power supply cord to the cameras. It was bad, I happen to have another one and that was it. All cameras working!
Dec 30, 2012 | GW Security Home Security
How can i connect a dome ccd to tv
just connect BNC Connector in the one end of the video cable and AV Pin on other side.Then connect BNC end to camera and AV pin to TV video port
Feb 15, 2011 | Dome 4 CCD CCTV Camera Surveillance...
I have 3 outside cameras (SSC-12C) hooked up need cameras
i recommend pelco day night dome camera they are cheap and the resolution is great. they are originally bnc type connector which usually take rg59 or rg6 coax cable but if you have like cat5 or some other kind of stranded wire you can by a balum adaptor that takes stranded wire but has a bnc female end. now with your monitor they make a cheap device called a multiplexer it takes bnc connectors and to hook up to your monitor you can use regular adio video cables like for your vcr. the multiplexer also lets you scan thru your cameras one at a time or have all three up or it can scan thru by itself like every five minuets.
Jan 17, 2010 | Samsung Weather Resistant Security Camera...
Unable to connect to the network on a SSC21web monitor
is this poe cam? cable footage over 300 ft needs cat5 extender if fiber check media converter to see if single or multimode also check media converter for tx/rx or using cat5 b crossover cable connect directly to laptop type in ip in command bar enter
Oct 12, 2009 | Samsung Weather Resistant Security Camera...
Connecting TV via LAN to a laptop as a monitor
You can connect any laptop to any TV with an SVGA port by use of a pair of Baluns. These run about $49 each; you need two. Try MCM.com. They have several models. As long as your LCD has an SVGA or VGA monitor  input the baluns will emable you to send a signal from laptop to display.
May 07, 2009 | Sony LF-X1 12.1 in. LCD Television
I have two samsung ssc-12c cameras.
green wire : 12v dc
clear wire : video ( + )
wire around clear wire : video and 12 vlt ground ( - )
you don't used the rest of wires . rest are audio .
Nov 20, 2007 | Samsung Weather Resistant Security Camera...
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
