Question about Cell Phones
My plantronics discovery 655 is blinking red blue and i dont know how to stop it so i can use it with my phone
  • glasgowj Apr 29, 2008
    Thanks but i know that it is in pairing mode. the issue is that it wont pair and stop blinking.
That means its in pairing mode....have you connected to your mobile Phone yet?
Posted on Apr 29, 2008
Can I replace the battery in the plantronics Discovery 650?
They are available on Amazon.com... http://www.amazon.com/Plantronics-Discovery-665-650e-Headset/dp/B00HYGMW3G%3FSubscriptionId%3DAKIAILSHYYTFIVPWUY6Q%26tag%3Dduckduckgo-d-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB00HYGMW3G
Jul 08, 2014 | Palm Plantronics Discovery 650/ 655...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    I have a 3xx plantronics blue tooth. It is charged and ready, but for some reason it will not connect to my cell phone. It used, but not its not. What do I do to pair it with my cell phone?
    Make sure cell phone is in discovery mode. Hold down power button on bluetooth headset until light starts blinking from blue to red. Your phone should find it. Then enter the code "0000".
    Aug 24, 2010 | Plantronics Cell Phones
    Lg lotus does not locate plantronics 925. have been using motorola h700 with no issues. have turned off phone and 925 and retried several times. lotus does not see any other devices.
    Once you make your LG Lotus discoverable, then put the Plantronics Discovery 925 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Discovery 925 pairing instructions.
    Plantronics Discovery Pairing Instructions
    Good luck from Headsets Direct!
    Apr 27, 2010 | Plantronics Explorer 330 Headset
    How do i get my plantronic 220 in discovery mode
    Hi,here is a detailed solution on how to set your plantronic headset into the discovery mode;
    STEP 1 You have to firstly put off the headset,by holding the call control button,which is the button on the face of the bluetooth,until the blue light turns red,as soon as the blue light turns red release the button.
    STEP 2 After putting off the headset,wait for like 5 secs to ensure its completely off.when the device is off,you can now press and hold on the call control button for 5secs if its the first initial pairing,if it's not,then you have to hold on the call control button for 8seconds,afterwards the light should flash red then blue in both cases
    STEP 3 At this point in time your headset is in discovery mode,and you have 60 seconds to pair it with your phone which should also be in the pairing mode as well.
    Your plantronics headset and your phone are matched up and you are good to go.
    Thanks and take care
    Apr 22, 2010 | Plantronics Explorer 220 Bluetooth Headset...
    Setting the discovery mode
    The user manual is here http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
    Press the button for at least 3 secs to getinto discovery mode Pairing and connecting Please note: You can only enter pairing mode from off position. Bluetooth® device must be in discoverable mode. Light Indicator flashes blue and red
    Apr 15, 2010 | Plantronics Explorer 320 Wireless Headset
    I have a plantronics 520,
    Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
    Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
    I need to know how to pair my plantronics discovery 925 - I have no user instructions
    set your phone to discovery mode. press and hold the button inside of the diamond until it flashes blue and red. once you do that, your phone should see it. Pair it to your phone by putting in code. 0000.
    Happy Calling :)
    Dec 19, 2008 | Plantronics Discovery 925 Bluetooth...
    I own a Plantonics Discovery 655 FCC ID: AL8-D665 I want to install it on to my razr and i dont know how.
    I have a Discovery 665 and I want to get it working with my MOTOROLA RAZOR
    can you help me
    Jun 29, 2008 | Plantronics Discovery 640 Wireless Headset
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
