Question about Kitchen Ranges
Coleman stove, model 412-5621, will not pressurize the fuel tank. The pump appears to need some replacement part or parts. What should I do?
Disassemble the pump by removing the c-shaped ring aroudn the metal cap. a flathead screwdriver will work to pry off the ring.
pull out the pump assembly. The end is probably a old dried out leather ring. It needs oil (car motor oil shoudl be fine) and it needs to make a tight seal.
if it is too loose, it might be possible to press it out to make it wider. If not, it needs to be replaced. The pump assembly is about 8 dollars at many stores.
Posted on May 02, 2008
How do i light 533
can you tell me more about your model?
Mar 14, 2014 | Coleman Camping, Backpacking & Hiking
What is a liquid-fuel stove?
Liquid-fuel stoves perform best in cold temperatures. They most commonly run on white gas using a refillable fuel bottle that is manually pressurized with a fuel pump.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
I need a Gas tank for a Powermate 2000 washer pump model PW0832000.02. Where i can get it?
After extensive searching the best I can come up with is to call coleman tech support at 1-800-279-9274 and explain what it it you need. This appeares to be an obsolete model as I was only able to locate parts for sprayer wand. Hope this helps you some. Thank you.
Mar 25, 2011 | Coleman Garden
My coleman 424 stove has been sitting in shed for a coulpe of years, now got it out again. Filled with petrol when pumped up I can light it but flame only lasts a few minutes then it dies as if no...
My best answer is that your pump seals have dried out and are allowing pumped up pressure to leak back past the pump seal
Try this: DO NOT LIGHT THE STOVE
Pump it up hard then quickly attach a small balloon with a rubber band around the base of the pump - where it contacts the tank. A deflated balloon or a small plastic baggie - does the balloon begin to fill with air after a few minutes - if yes then your seal is leaking.
You might try taking the pump apart and soaking the seal overnight in fuel reinstall and see if it cores your problem
Good Luck
Mar 22, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
VALVE WHEEL LEAKS
Here is Coleman's repar part website.
You may want to replace the valve if it is leaking.
http://www.coleman.com/coleman/parts/product_category2.asp?category_id=210
Jul 21, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 424 Dual Fuel -- High, yellow flame
Are you pumping the tank up all the way? I have the same problem if I have too little pressure in the tank. The instructions say pump 35 times. Try pumping 50 or 60 times- that seems to help.
Also, you can't light this one like an old 425. My old stove you could turn the gas on and then take a match neat the burner. For this stove, hold the match near the burner with the gas off and quickly turn it on.
These are two things that seemed to help me with the same problem.
Jul 11, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman 425 2-burner white gas stove pops out flame on low heat
There is water in your fuel. Drain the tank and flush it out with denatured alcohol. Refill with fresh fuel.
Jun 21, 2009 | Coleman Sport & Outdoor - Others
Coleman 424-700G Burner/Pressure Issue
I had a similar problem today, After taking the ump assembly to pieces i disovered that the pump"stem" needed turning slighty anti clckwise to allo tepresure to build up inthe tank. I felt very stupid buta big learning curve for me.
Sep 28, 2008 | Coleman 2 Burner Dual Fuel 424-700G Grill
Kitchen Ranges Logo
686 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
