Question about GE EasyCam Webcam
Cam works but stopd when computer is stopped and started again
I can load the software drivers okay, but the next day whrn I go to yse it on Skype it won't work and I get a error message that says the graph can ot preview
Nu am disc
Posted on Nov 27, 2008
How to use skype 6.0 with logitech c-310
Launch the Logitech QuickCam or Webcam software on your computer. Verify that you see yourself Logitech Webcam software window. Close the software window. Sign in to Skype. Click the "Tools" menu and select "Options." Click "Video Settings," check the "Enable Skype Video" and "Start my video automatically when I am in a call" boxes. Select your Logitech QuickCam from the drop-down list. Your webcam should display video in the window. Click "Audio Settings" if your QuickCam has a built-in microphone and select it from the microphone drop-down list. Check the "Let Skype adjust my audio settings" box in "Audio Settings" so Skype recognizes your microphone. Click "Save" to save the options for your audio and video settings. Skype will close the options menu.
Jan 19, 2013 | Logitech C310 Web Cam, Skype, Computer...
Web cam previously worked then suddenly stopped
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7
click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark?
hope this helps
Jul 15, 2012 | CyberLink YouCam
Web Cam not working... HELP Please
First, you are NOT the only one. Skype seems to be having issues. I teleconference with Skype 20 times a day. 1/2 the time the cameras work and 1/2 the time it doesn't, and it could be mine or the person I called that doesn't work.
Check and see if you have the latest version of Skype. If not, download and install.
Try your webcam software as if you are going to make a video. If the camera works, it's most likely Skype. If not, start troubleshooting the camera.
Nov 19, 2009 | Computers & Internet
I use the logitech e3500 web cam with skype but
If it is sometimes then could be a problem witth the hardware but still you can try reinstalling the drivers.
Sep 08, 2009 | Logitech Webcam
Skype vs AMCAP v.9
Have you tried reinstalling the Skype software or the webcam driver?
If not, you can try to do the reinstallation. Make sure you get the the compatible drivers, softwares for your operating system.
Aug 25, 2009 | HP EW192AA Webcam
Webcam wont install
Normal 0 GE PC Cam Drivers
http://www.jascoproducts.com/support/software-downloads.asp
Then
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps
Mar 30, 2009 | GE EasyCam Webcam
Quickcam for SKYPE
Hopefully you have not loaded the quickcam software yet. If you have, hopefully you only loaded the drivers for the cam and not the logitech control panel for the camera. If you loaded the control panel, it loads everytime you start your computer and runs minimized in the bottom status bar. When you start Skype, it activates the camera and so does the logitech control panel. Thus you have two programs trying to control the cam at the same time and you have nothing but problems thying to get it to work. You will need to right click on the logitech control icon and exit the program before starting Skype. After you start Skype got to tools, options and set your camera and mic. settings from the drop down menu. You can then go to Skype test call and see if the settings are correct. Skype allows you to turn on the video or off when you make calls to others. This is so they can't see you, but you can see them during the call unless they have theirs turned off also. Good Luck, RAC
Mar 03, 2009 | Logitech QuickCam Connect Webcam
GE EasyCam Webcam Logo
194 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
