Question about LG PREMIER - RD-JT50 RD-JT52 - AJ-LT50 DLP Projector
Projector lamp not switching on
I am using a RD-JT 91 or 92 Premium DLT Projector - mounted pretty high in a roof. The projector cannot be switched on. No LED indications are shown. Around the centre control bottons, 4 blue LED's are flashing similtaniously - indicating we have power at the unit, but the manuel has no troubleshooting assistance to indicate what this in fact means.
  • 563 Answers
Hi Altus
Wich country are you in ? I can try and direct you to a repairer for this faulty Mainboard.
Posted on Apr 29, 2008
NEC M420x blinking and no light, can help me /
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 10, 2013 | LG RD-JT52 Replacement Lamp
Red lamp or heat light is flashing while projector is off. Can't be sure which it is because it is mounted 16' up. I've cleaned projector & filter with canned air from 12' ladder and red light stops...
Here is some information on this model which I hope will help...
The lamp indicator lights when the lamp is due to be replaced. It will flash if a circuit abnormality is found.
The temp indicator lights if an abnormal temperature is detected. If it goes too high it will shut down flash.
The lamp indicator is furthest away from the power switch if that helps.
If the lamp timer was approaching the end of the lamp life you would see a REPLACE LAMP nag screen when the projector is turned on. The fact that you have not mentioned this suggests that this is unlikely to be the problem.
The filters on the model are on the underside. There is a removable panel directly under the lens. You should not use canned air as you are blowing dust into the projector. It is recommended that you use a vacuum cleaner. Filters should be cleaned every 100 hours and replaced when the projector is relamped. You can wash the filter by hand with water only, ensuring it is dry before replacing it. Do not run the projector without the filter in place.
Feb 19, 2011 | Panasonic Projector Lamp for PT-LB50...
Projector won't turn on
make sure the lamp door is engaging the safety switch. make sure the colorwheel spins also, it the colorwheel doesn't spin up the projector won't start.if thats not the problem you need to check the resistance on the thermal switch which is on top of the lamp housing. it should be infinite. if thats not it it could be the power supply or the main board.
Jun 25, 2010 | InFocus ScreenPlay 4805 Multimedia...
Dlp projection, keeps switching to standby, also sometimes will start up and the picture goes blank but the sound remains
The lamp may be out. Projectors need high voltage/wattage lamps. They tend to only last 2000 hours or so, which is about a year or two with normal use.
Feb 04, 2010 | LG DLP Projector 1400Lum RD-JT30...
Lamp reset timer
Hi there
There is basically two ways to reset the lamp timer :
1. ) On the Projector's physical buttons
Arrow Keys - Up , Down , Left , Right then Menu and Enter - this should be done quickly whilst the Projector is in standby mode.
2.) Switch Projector on - Hold in the Up Arrow Key on the physical buttons on the Projector untill a PIP screen appears - then just follow the on screen steps.
Sep 25, 2008 | LG RD-JT91 Multimedia Projector
LG RD-JT 21
Hi Mike
Press the following buttons quickly - Up , Down , Left , Right , Menu & then Enter - this should reset the timer.
Sep 16, 2008 | LG RD-JT91 Multimedia Projector
Resetting lamp on a lg rd jt40 projector
remove bulb. replace bulb. within ten minutes press exit on projector and hold for three secs. then immediately press menu then press left or right arrow button. you are done. turn off then turn on
Jul 04, 2008 | LG RD-JT40 Multimedia Projector
RD_JT 91/92 DLT Projector not switching on.
Hi Altus
This a common Mainboard failure on the LG JT91 if all the LED's flickers.
The good news is that it can be repaired. Much cheaper than replacement.
This will however have to be done by a Service Provider.
Apr 29, 2008 | LG RD-JT91 Multimedia Projector
RD-JT40 powers on but nothing shows
check the lamp,
does it look clean inside
is it fully home on the connecting pins
are the lamp door and fan switches made correctly
Feb 26, 2008 | LG RD-JT40 Multimedia Projector
Help me Please
I have just reset my lamp! Disconnect all cables but the power, switch on it will search for a source, the lamp timer message will display press exit untill it will give you a message to press menu to reset the lamp timer, it will give you a option to press left or right to reset. I used the buttons on the projector not the remote.
Jan 31, 2008 | LG RD-JT40 Multimedia Projector
LG PREMIER - RD-JT50 RD-JT52 - AJ-LT50 DLP Projector Logo
199 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
