FixYa.com
Tags:
Nikon Telephoto AF-S Nikkor 600mm f/4D ED-IF II Autofocus Lens - Black
Problems with Nikon Telephoto AF-S Nikkor 600mm...
posted by 600 fix on Apr 29, 2008
Has any one had a problem with nikon 600 f4 ED-IF 1 autofoucus lens.
Problem is with the circuit board. An intermittent problem when you put the lens on a Nikon camera and pust the shutter it usally focuses. You wait your 15 sec and the camers shuts itself off. Now when depressing the
shutter button ithe autofocus should kick in but mostly does not. seems to me it has hung up or something. You take the lens off and back on and it resets. Contacts and mount was replaced by nikon but they do not seem to know how to fix it.To me seems not a psysical thing that can be changed by tapping on the lens. Most likely the circits are not activated in on of the chips.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Apr 29, 2008
Helpful (85)
jerryg50
Rank:Wiz Wiz
Rating: 84%, 453 votes
It sounds like the circuit board in the lens is intermittant or there is a bad connector contact internaly where the circuit board connects to the harnesses.
Trying to find a cold solder connection on a multi-layer circuit board with SMD technology componts is not usually very feasible and reliable.
A major cause of this type of failure is from humidity, and or banging or dropping the lens unit.
I would start by changing the circuit board and the connector assembly inside the lens. This is an expensive fix, but it is effective.
If you request the described repair and offer to pay the cost, I am sure they will do it.
Jerry G.
Rating Locked! (?) 600 fix has rated this solution as Helpful
Can you Help with these Camera Lenses problems?
Camera Lenses
Digital Camera S760 Sumsung....
I have a digital camera. Its a... Answer This...
Camera Lenses
HELP ME TO INSTALL
please help me install my A4... Answer This...
Camera Lenses
af motor required for a canon...
HI, My name is Nick, I'm trying... Answer This...
Camera Lenses
test dont answer
test dont answer Answer This...
Camera Lenses
i will never shop here again...
best buy, my foot best buy has... Answer This...
Repair Service
Find Camera Lense Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
